Starter Going Bad?? |
Post Reply | Page 12> |
Author | ||
davidg
Grand Poobah Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Posted: July-08-2012 at 3:11pm |
Recently, when I start the boat, it is acting like the battery is weak, and barely wants to turn over, especially after its been running for awhile, but, the battery is new. Is this a symptom of a bad starter?
Are they hard to rebuild, and where is the best place to order a rebuild kit from? Thanks! |
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
the only thing you can "rebuild" in a starter is 4 new brushes. other than that you cant rebuild them. and yes. you could have one re-wound but thats big bucks. you have an old starter with a short somewhere and it pulls a lot more amps than it should lowering the voltage significantly at the stater. that happened to our Martinique. the guy before us put in a HUGE deep cycle marine/rv battery. but we pulled the mini high torque starter from our supra and it turns the over the lower compression 351w in the Martinique like no tomorrow!
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
89Martinique
oh forgot to add. you can get a marine mini high torque starter brand new on ebay for $60!! its for omc but it for a ford 351w so its the exact same starter. we ordered one for our supra only to have my grandmas Martinique have a bad starter this year. so it went in her boat instead ours. it works great and was cheap. search "OMC 5.8 ford marine starter" or something like that and you should find them. we just ordered a second for our supra again.
Current Boats:
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5312 |
David, it could be a sign of bad starter and you can send the starter out for a rebuild if it is indeed bad. Check ALL contacts for looseness or corrosion before going after a starter. How are the cables from the battery to the starter itself? Is the new battery a DEEP Cycle battery? If it is then that's probably the culprit
davidg
Guys.....Thanks for the advice.
Also, Tim, yes, I do believe I bought a deep cycle battery, marine battery. I will have to check it out. How would a deep cycle marine battery cause this to happen? |
Dave what ever you do, do not take it to the guy on RT31 and Virgina by the tennis club, AGS Rebuilders. Go to MG Auto Electric 500 S. Arthur Ave in Arlington Heights way nicer people to work with. Ags has been sold and he's not a good communicator.
davidg
Gary.....Thanks for the advice. I hope I won't need a rebuild. I just went out and checked for the connections, and the nut that holds the cable on the starter motor itself was loose, and barely making contact, so I am hoping that is the issue. Now, the whole deep cycle battery thing has me a bit concerned as well.
Regardless, now that I have the boat back here in IL (just brought it back from WI), we will have to get it out on the river and do some boating. Although, the water level looks low, and I don't want to take ANY chances of banging up that new 542. I may have to throw a real junker prop I have on there for river duty. |
You going to Green Lake? If I do go out on the Fox it's going to be to give John B a ride so he has some more motivation to get his done. Then Im going to pull out the floor,change all control cables and start putting the pan and console back in.
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
Dave, The deep cycle is designed to put out small amounts of juice for long periods such as running an amp or trolling motor. A starting battery is for big bursts of power like a starter. Pull a car battery out a vehicle and give it a try. That should answer the question.
1987 Ski Nautique |
davidg
I don't think we are going to GL. Got a long weekend the following weekend. I take you are going? Let me know if you need a hand with anything.
In fact, you can take John and I out for a ride. We can discuss politics over a cold beer |
I'm not getting in the middle of that
OverMyHead
You might want to pre-medicate with a few before you start!
1987 Ski Nautique |
davidg
Guys.....For what its worth, I checked with my Ford-trained mechanic, and he indicated that it is not a problem to run a deep cycle marine battery on a 351 automotive engine.
I am a bit confused now on whether I will have issues running that battery. I would appreciate hearing any thoughts to the contrary why a deep cycle won't work. I had not heard that before. I bought the marine battery because I thought the deep cycle aspect would help because I was going to leave the boat in the water for an extended period of time and I wanted to make sure the bilge pump kept running. |
OverMyHead
Dave, There was just another member with the same issue, starting battery solved his problem. I would swap a regular starting battery from one of your cars in there to rule out that cause before you waste time on anything else.
1987 Ski Nautique |
OverMyHead
You could put in a battery switch and run a separate battery for that purpose, but you need a starting battery for starting.
1987 Ski Nautique |
davidg
Dave, so you are saying a deep cycle battery isn't really for starting? I didn't realize that. When I bought the battery, it said 750 cold cranking amps, and had other specs that a normal battery has. So, I thought it was a normal starting battery with special capability to help auxilliary equipment...ie...pumps, lights, etc.
I tighted the nut that holds the cable on the starter, so I am hoping that solves the problem. Its in the garage right now, and jumps right to life when I hit the starter. But, if the problem persists, I will pull the new battery out of my truck, and put it in the boat to see if that helps. |
OverMyHead
Dave, There are batteries that are marketed as combination deep cycle and starting. Though I doubt the claim (jack of all trades, master of none)one of those should be fine for stating. A pure deep cycle is not.
1987 Ski Nautique |
OverMyHead
Basic Battery Types
There are two basic types of 12-volt batteries: 1) cranking, or starting, batteries, which are designed to start your main engine, and 2) deep-cycle batteries, which are used to power electrical accessories such as trolling motors, fish-finders and radios. Dual-purpose batteries that can perform both these functions to some extent also are available. Cranking Batteries Engine cranking requires lots of power in a short burst. A battery with more surface area on the lead plates inside it delivers more fast power than one with less plate surface. For this reason, cranking batteries are made with thinner, more numerous lead plates. When the engine is running, the battery is quickly replenished by the alternator. The marine cranking amp (MCA), or just cranking amp (CA), rating found on a battery's label measures a battery's starting power. And if you're using a newer model outboard with sophisticated computers, pumps and sensors that don't take kindly to being underpowered, you certainly don't want to scrimp on starting power. Check your engine's manual for its recommended MCA/CA rating before shopping for a battery, and always choose a battery with a rating equal to or greater than the recommended value. Deep-Cycle Batteries Trolling motors and other accessories sip power at a slower rate for extended periods. Batteries that power them usually aren't recharged until the end of the day. These deep discharges are hard on battery plates, so deep-cycle batteries have fewer yet thicker lead plates than cranking batteries and are built to withstand deep cycling. A deep-cycle battery's reserve capacity (RC) rating indicates how long it can carry a specific load before falling into the dead zone. The higher the RC number, the longer the battery will power your accessories. Remember this when choosing a battery. Typically, a deep-cycle battery will have two or three times the RC of a cranking battery. A deep-cycle battery also can withstand several hundred discharge/recharge cycles, while a cranking battery is not designed to be totally discharged. No Substitutions The key thing to remember when purchasing cranking and deep-cycle battery types is not to substitute one for the other. If you use a cranking battery to power your trolling motor, for instance, the battery will soon overheat and fail, leaving you without power and requiring you to buy a new battery. A deep-cycle battery substituted for a cranking battery, on the other hand, may not provide the power needed to start your outboard. You could get stranded with an engine that won't run. The inherent design strengths of each battery type also are their weaknesses in opposite applications. Dual-Purpose Batteries It's usually best to install separate cranking and deep-cycle batteries. If your boat is small, however, and there's only room for one battery due to space or weight restrictions, consider buying a dual-purpose marine battery specially that handles starting and cycling. Bear in mind, however, most dual-purpose batteries won't start an engine quite as well as a true cranking battery and won't endure as many deep discharge/recharge cycles as a dedicated deep-cycle model. |
1987 Ski Nautique |
89Martinique
we just have a large(is actual size) deep cycle marine/rv battery in our Martinique and its fine. a regular 351w is very easy to start even with the old school plunger type starters
Current Boats:
davidg
Good information Dave. Thanks for that. I just went out and checked out the battery. It is a "dual purpose" marine battery that has seperate posts to hook other gadgets up to. So, I am somewhat relieved I didn't buy the totally wrong kind of battery. Either way, in the future, I will be a much wiser buyer on batteries.
OverMyHead
That is good. Hopefully the starter connection was the issue.
1987 Ski Nautique |
Morfoot
IF you think about it for second. WHY do most bass boats if not all have THREE battery's in them. TWO are deep cycle for running the trolling motor on either 12 or 24 volts. Just as Dave's description above. The THIRD battery is for cranking the motor, PERIOD. That's its sole purpose in life. To provide the AMPS to turn over the motor and fire it up.
Another way to look at it is you don't use a deep cycle battery to start up your car so why would you use one to start your boat? It's basically the same motor. |
ononewheel
Gold Member Joined: June-21-2011 Location: B Status: Offline Points: 776 |
I'd put my money on Dave's advice, he's got the right info for you. It's been discussed over and over. Cranking/starting is what you want, even if the other battery says "MARINE" or what your mechanic told you. Will it start it? sure. For awhile, until it starts to fail accepting a charge or fries a starter or you need to replace the battery sooner than expected, or an alternator.... that is gas money out the window. Do it right. There has got to be something in the manufacturers producing the two types. |
If we let the professionals do everything it takes all the fun out of youtube
89Martinique
Well a 351w is an extremely easy motor to turn over period. the previous owner of our Martinique thought he had a bad battery so he threw in a huge ass deep cycle battery. but what was wrong is that the starter was shorting. so we put the mini high torque one from the supra in the Martinique. the mini's use less power and produce more torque and crank the engine faster. the battery is still fine. charges right up. we left it hooked up over winter and it still started up just fine. and there is a major difference between how a cranking battery, deep/cranking battery, and a deep cycle battery are made. it all has to do with the size of the lead plates, the solutions used that dissolves , etc... |
Current Boats:
OverMyHead
[QUOTE=89Martinique]
the previous owner of our Martinique thought he had a bad battery so he threw in a huge ass deep cycle battery. but what was wrong is that the starter was shorting. so we put the mini high torque one from the supra in the Martinique. /QUOTE] It sounds like you fixed the problem caused by the wrong battery by putting in a starter that draws less amps. Seems easier just to put in the right battery. |
1987 Ski Nautique |
89Martinique
thats not at all what happened. he told us he had a bad battery so he put a big one because it was hard to start. but it was the starter. the battery hadent hurt it all. the 2 awg wire from the battery was almost hot to the touch after trying to start the boat and the battery is still in good shape. so it was putting out plenty of enough amps. a big block engine you definitely would not want a beep cycle for. but a small block it doesnt make much difference unless it has higher compression like our supra |
Current Boats:
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21125 |
I have seen deep cycles cause starting issues on small blocks. Even with supposedly-sufficient CCA ratings. I suspect their construction makes them a poor choice for short duration, high current loads, as opposed to the longer duration, low draw loads like trolling motors and stereos.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Wrongo A dc motor is a dead short at 0 rpm. A typical deep cycle battery cannot deliver BOTH high current and high voltage, only one or the other. Power = Current X voltage, so high current at a low voltage means low power delivered, low rpm, but also lots of waste, because P=RI**2, the cables and starter got hot with all the extra current, meaning the starter saw even less applied voltage, so it spun slower, acted more like a dead short, pulled more current, more resistive loss, etc and so on. I concur, this problem likey began with the battery. Seen it many times before, and we'll keep seeing it as long as they keep writing MARINE on deep cycle batteries. |
River Rat to Mole |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
I agree, the PO of my boat had a new deep cycle marine in, and I swapped out for a commercial truck battery with 900CCA and it turned over almost twice as fast. Buy a good starting battery.
Remember that engine is a car block. The only thing that makes it marine is a few safety pieces and a couple accessories. You wouldnt put a marine battery in a 86 Ford F150 would you? |
Dump the deep for a starting battery. Ether that or pull the engine and put a trolling motor in it's place!
BTW, was it that mechanic of yours that sold you the deep? |
