  New Posts New Posts RSS Feed - marvel mystery oil
marvel mystery oil
surroundsound64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Topic: marvel mystery oil
    Posted: July-29-2005 at 4:11am
The directions are on the bottle. If you use it in your crank case you are supposto use the whole quart, but you use it instead if 1 of the quarts of oil. DO NOT OVER FILL THE CRANK CASE! If you need 5 qts of oil, make it 4 of oil and 1 of MMO. Check the level frequently though b/c the MMO does evaporate out eventually and you will need to put the quart of oil back in.
1981 Ski Nautique
2000 SAN
Looking for a 2000-2006 SAN
captan1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 9:45pm
Has anyone looked at this stuff and said,, Looks like Marvel ATF, looks kind of like automatic trans fluid.
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 4:30pm
bottle says 4 oz. per each 10 gallons of gas. and i think it says a whole quart mixed with oil
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 5:29am
I put it in a spray bottle so I can squirt into the plug holes in the off season.
You only a put a few ounces in a tank of gas. I add about a cup to a new oil change.
When re-building, we bathe everything in the stuff and the rotating torque goes down as compared to regular 30W.
I have the old heads on my boat and since the stuff is an upper cylinder lubricant it may help with the "no-lead" dilemma.
A little overkill...but these old boats deserve it.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2005 at 1:05am
What this stuff actually does is a mystery to me. Maybe I can use it to clean my BBQ grill. A cup seems like a lot. Can you put it in a spray bottle?
Darrel View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrel Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2005 at 10:52pm
I always have a bottle of it in my "boat box"
I add it to about every other tank of fuel, not a lot about a cup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2005 at 1:37pm
How much do you put in your gas-oil and what are you expecting to gain? I've always thought of doing that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2005 at 10:49am
I run in both. Kinda old school, but it works. I try to use it in every tank of gas and also use it to fog prior to set-up.
64 Skier
71CC
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2005 at 1:05am
do you guys use it? in gas or oil or both? how often?
