Rolling fwd an hour meter |
aokcaldwell
Groupie Joined: October-11-2007 Location: United States Status: Offline Points: 95 |
Posted: August-16-2008 at 3:06am |
My hour meter took a dump. Any way to roll the hours fwd.? I want the correct hours on the new meter.
Thanks, Adam. |
aok142
1999 NSS GT40 Pro Boss |
OM45GE
Senior Member Joined: September-07-2007 Location: United States Status: Offline Points: 109 |
Nice to see an honest person! There's home for the world yet!
What year is your boat you want to do this one? I think the meters are driven differently on the computer controlled motors. |
1989 SN 2001
aokcaldwell
I have a 95' Ski Nautique. I had to purchase a Faria hour meter as they do not make the original one.
Adam. |
aok142
eric lavine
I always thought your suppose to roll them back lol,
hour meters are great for maintanance purposes, as for purchasing a boat i hav'nt believed one yet |
bkhallpass
Kind of related threadjack. I'm seeing a lot of boats for sale from the early 2000s advertising unbelievably low hours. Beware. About half the boats I've looked at have had the hour meters replaced. The electronic guages in the early 2000s are known to fail and it appears that many of the sellers are less than honest. BKH
Livin' the Dream
JoeinNY
adam just hook the meter up to the battery and come back after the desired number of hours have been added then install, might take a month but it will work...
aokcaldwell
I appreciate the help. I put my boat up for sale to upgrade (Air Nautique possibly) and when I told the buyer about the meter he got spooked! I had the original meter, the previous owner's number and the mechanic who serviced it. I told him the boat speaks for itself. Good luck in your search for a new boat. Thanks, AC. |
aok142
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
I'm not sure ,but I think you can hook up the computer on the motor and it will hold the correct time on the engine.
MaddMarxx
Joe, is right, just turn the key on, the motor does not have to be running!
aokcaldwell
Not sure if any Nautiques with GT-40's had ECM's modules until about 01' and I know that the key has to be on and the ignition button in to roll the meter. I've already tried.
Anyone? Adam. |
aok142
bkhallpass
Your correct Adam. On the newer boats, the hours meter doesn't simply run because the key is turned. I've read a lot of posts with the same question and I've never seen anyone identify how to advance the hour reading on the electronic guage used in the 01s. Also, the from the chevy's you can look up the actual hours on the engine's computer. Not so on the Fords. BKH
Livin' the Dream
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
Can you disassemble and manually adjust the numbers.? Obviously this will only work for anologue.
aokcaldwell
Hey, I forgot to reply to the post! The meter has successfully been rolled fwd to the proper hours. Prior to installing the new meter I hooked a 2amp trickle charger to the posts and let the meter fly. Took over a week for 365hrs. Just make sure the polarity is right. The OEM meters have a +/- on the back.
aok142
