83 New Stringers & Floor |
Post Reply | Page <1 789 |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
URGENT REQUEST
I'm looking for more vinyl trim for carpet(Pic). I bought all one supplier had and he said will not be getting anymore. Gundriver sent me a link from Nautique Parts-bought 12 feet and it is not the same . I need 12 feet if anyone knows where to find. Thanks JT |
jterr
Hello
jterr
Long Time Coming -Motor going back in
jterr
Problem- motor mounts on drivers side or off, got to figure out how to adjust mounts
jterr
Any info on replacing the O-ring behind shifter on tranny??
The info in the link might work for you
CRMav did his with a 210 O ring and still had some leakage, (not sure how much) maybe his case is scored or the O ring wasn't quite right. I've used a 210 O ring with no leaks link |
jterr
Done Thanks |
jterr
Question- after replacing those cutlass bearings in the strut it is really hard to turn prop shaft, do they just break in normally??
Put some soapy water on the cutlass and try again. If that's doesn't help, then it sounds like you need to do some more alignment. |
jterr
Should one turn on each motor mount be the same travel???
Same thread pitch so yes. |
jterr
Here is another dealing with that shaft coupler , I got it the same all the way around with a gauge.
Question is how to get it .003 without using the nuts and bolts? I'm not strong enough to push I guess... |
John, You may have missed the point of the .003". The .003 is the max difference between the faces of the couplings all around and not a specific .003. Say you measure .013 on one side and .010 on the other, then you are within spec. You are checking for the shaft to be parallel to the engine. |
jterr
From this angle I see a little daylight. Bolts are there for lining up holes not tight.
John,
I'd double check to make sure you don't have more than the .003 difference top to bottom side to side. EDIT: John, I'm getting the feeling that you may not be grasping the concept? The gap shown in the picture looks to be over .003 so, if the opposite side gap is zero, then the alignment isn't good.
Is the prop shaft "happy" (turns freely) in the strut and is close to center in the log where it is now? |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 891 |
Also, is the prop on?
If not, the weight of the coupler will cause the shaft to be lower at the trans than might otherwise be. Possibly resulting in motor too low. You should have to hold the coupler up away from the floor slightly to get an initial good fit. Once in the water and run around a bit, it will need re-adjusting. |
1994 Ski Nautique "Riot"
jterr
Raining here in N. Florida so time for Q & A.
#1 Was looking under boat and noticed the prop and rudder aren't lined up, how can that be?? #2 Suggestions on how to fix to just paint?? |
Because it was built by Correct Craft. But, you may what to check to see if the strut isn't bent and is centered. Measure from the chines to the strut center. |
jterr
Where does the fuel gauge get power from as it isn't working , and has a new sender. Couldn't be hooked up wrong
From the positive feed off the ignition switch/circuit. The sender is the negative source. Grounding the sender wire should peg the gauge. Is the fuel tank grounded? Ohm it to check. |
John,
Here's your diagram: Have you been following it?
Considering all the problems you're having with the wiring, maybe you should just rip it all out and start over? |
jterr
Update on Steering Wheel Hub, not great but better than previous look
jterr
But I'm having so much fun getting to know my Boat |
jterr
OK I got pics the best I could behind dash showing wiring as I remember. If you look at wiring diagram (above post) it shows AMP where I have a Voltmeter.
No Orange Wire Behind Dash Tach |
JT
You have too many topics in different threads The voltmeter was mentioned 4 days ago in the thread about the tach in the "engine rebuild" thread. See the last sentence of the quote below Seems like you're in between early and late diagrams with that boat as CC was switching to voltmeters about then. Your 10 gauge Red wire from the harness should go to the BAT terminal on the key switch and the 10 gauge Orange from the harness would go nowhere and have no power on it.. Back at the engine the 10 gauge Orange from the alternator would go to the breaker or the starter solenoid to give the charging path to the battery with the voltmeter setup and the Orange that runs up to the dash would be cut and taped off. It's kinda hard to explain without being there If you had an ammeter that 10 gauge Orange wire would have power going up to the ammeter, then from the ammeter it would go to the key switch thru the Red wire you're missing
jterr
Sorry I thought it was to my 83 rebuild thread. Hey at 75 I feel lucky just to be crawling around ,under and over this boat
FYI I have the e-mail Notify checked and still not getting any notifications |
jterr
Here are a few before/after pics:\ well all I can get to load
