  New Posts New Posts RSS Feed - 93 SNOB restoration
93 SNOB restoration
Lens93SNOB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Topic: 93 SNOB restoration
    Posted: September-29-2019 at 2:06pm
HI Correct craft world,
I've begun the restoration to my 93 SNOB and I thought I would post an update in case there are any fans of these middle aged beauties!
It had been sitting for almost 3 years and exposed to the elements and it didn't look as if it had been properly cleaned for MANY years. The exterior was heavily oxidized and so some heavy elbow was needed. I did a wet sand with 600, another with 1000 and then 3 passes with the 3M heavy oxidation compound. After that, I concentrated on the part of the hull where the old graphics used to be as I wanted to get the fading out. SSSSssoooooo, I sanded again with the 600, then the 1000 and did 2 more passes with the compound. And, Voila! She turned out beauty. I picked some new decals off on NautiqueParts from a 2006 SV21 as I wanted to give it more of a modern, new school look. I'd love to hear some feedback from you guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2019 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2019 at 4:50pm
I couldn't get the 'before' picture to upload, but I'm sure most of you have seem a heavily oxidized before : ).
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2019 at 4:58pm
Gel looks like it cleaned up very well. Congrats!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2019 at 4:58am
It is looking pretty! Nice work.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2019 at 1:16pm
Awesome!!! Well done.
mckeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mckeddie Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2019 at 4:29pm
I love that blue!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2019 at 12:19am
Can anyone tell me what parts are exclusive to a 351w reverse rotation motor besides the camshaft? Do I need a different oil pump? alternator? My water pump is fine so I am going to re-use it. Any help is appreciated!
beretta5spd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beretta5spd Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2019 at 12:39am
distributor gear for sure
1996,1997 Sport Nautique 1986,1992 Ski Nautique - Sold
1995 Sport Nautique - Current
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2019 at 12:54am
Oil pumps still run the same direction no matter the engine rotation. Rear crank seal is rotation specific, front one I believe is too but a plain one with no wick lines should work -someone should know which one to use. Camshaft you already know but the distributor gear which you already have, has to match as well. Alternators can run either way, make sure it's a marine one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2019 at 10:13am
For the rear main seal for your 93 351 with a one piece seal the link below gets one at a reasonable price
or you could find a PCM R047041A for 3 times the price
For the timing cover seal a FelPro 17795 works, it's a smooth seal with no wick lines in the rubber and works with either RH or LH engines
And just to mention the obvious, if you're changing starters you need a reverse rotation starter.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2019 at 11:52am
Great work! I'm of the opinion that a brand new set of the original 1993 graphics (including the gray pinstripe above and below the main stripe) would make that an absolutely stunning boat. Still looks good, of course, as is.
I went back and dug up the process I went through on my 93 back when I had one a few years ago: 1993 Decal Replacement and Polish
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2019 at 2:47pm
I am such a huge fan of the older nautiques but I am far from a fan of their older graphics. I was going to keep it true to the year but the more I thought about, I just couldn't do it.
I'm really hoping that when I'm done that it will look a little more fresh and updated and maybe even show some nautique critics that these are truly the nicest early generation ski boats ever made.
I'll have more updated pics of it soon!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2019 at 2:59pm
You must be a relative youngster if you're calling a 93 an older Nautique and an early generation ski boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lens93SNOB Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2019 at 6:34pm
The major restoration work on my 93 has begun and I've managed to get quite a bit accomplished over the past 2 months.
-Engine removed and is being rebuilt at a local shop.
-Flooring removed
-Engine bay completely degreased and cleaned up (It was really bad)
-Gel coat restored with new decals
-Steering cable
-New flooring being installed at the moment
-Trailer wiring and new Fulton winch installed
Engine is staying completely stock with the exception of an Edelbrock Torker 2 intake manifold and upgraded Holley 4010 carb which I for an absolute steal. I am hoping to get the short block back next week and I will update this once I have the motor assembled and painted.
Mille1sj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Posted: December-05-2019 at 10:52am
Good looking boat, my neighbor has the same boat in red. Interested in seeing what you did with the graphics.
flyweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flyweed Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2020 at 6:49pm
Looking good. SO question about your new flooring. I have a 93 Ski (closed bow) and want to replace the old worn out carpet this spring. What product did you use? Was it precut, or did you do the cutting yourself? Did you make templates?? Any info you can give another 93 owner wanting to do their floor would be great. Thanks
Drink Tonight..for tomorrow We Ride!
