  New Posts New Posts RSS Feed - Air breather
Air breather
AlfaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Topic: Air breather
    Posted: September-26-2019 at 9:19pm
I want to change the air breather that’s on the valve cover of my 351W. It it possible to rotate it to change the breather hose orientation?   Or, is it ok to remove it and use a breather that sits on top of the valve cover, one that you can pull out to fill the engine oil? Is it a problem to vent the blow by gases into the dog box instead of the hose that sits in front of the spark arrestor?
The current hose configuration blocks my view of the fuel pressure gauge
Thanks
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2019 at 9:38pm
Don,
I feel it'd best to relocate the gauge rather than mess with blow by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2019 at 11:18pm
Thanks
Don
You must be talking about the oil fill pipe with the hose that goes from the side of the pipe over to the flame arrestor.
I don't see any problem with rotating it if you can or removing it and just putting a breather/fill cap in it's place .
If you look at a diagram of how the PCV system works, air goes into the engine through that tube or cap and ends up carrying blowby gases through the PCV valve back into the intake manifold
Depending on PCV valve condition, the amount of blowby, and engine vacuum, blowby gases can come out of the breather/fill cap instead of clean air going in.
If you google "PCV system" you'll find various explanations of how the system works
The automotive system draws air from inside the air filter to get clean air without dirt,sand etc flowing into the engine. The marine system on a PCM 351 draws air from outside the flame arrestor since you really don,t have to worry about dirty air
Another reason I figure it should work is one of my boats has the fill cap/breather setup with no hose running up to the outside of the flame arrestor along with the normal original PCV valve setup and there were no differences in how it runs as compared to the original setup.
I'm not sure on long term affects, it's only gone a few thousand or so hours this way
Why are you still looking at fuel pressure? I thought your new pump and overflow line hookup had it running good.
I never tried to rotate that tube, but I have an old valve cover with that tube and I can try to rotate it in the morning and see if it turns easily, breaks or just refuses to move.
I'll let ya' know
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2019 at 11:41am
Don
If what you have resembles what's in the picture, it will rotate. I had to delicately use a pipe wrench for some leverage but nothing broke or twisted.
And I even rotated it back to it's normal position again
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2019 at 3:37pm
Thanks guys,
Pete, I understand you concern. That’s why I asked. I can put a 45* fitting behind the gauge and it should Move it out of the way enough to accomplish what I’m trying to do.
Keno, My filler looks just like yours. I tried rotating mine with a pair of channellocks and despite being cautious all I did was put a dent in the neck.   I finished modifying my spark arrestor to accommodate the vent hose. I’ll post a few pics to the other thread later tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2019 at 6:22pm
Thanks guys,
You obviously need more practice at "delicate brutality"
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2019 at 7:32pm
Don
I stumbled into this picture of a 302 Ford in a Tique with just the breather cap and no hose up to the flame arrestor. like I mentioned earlier.
I just can't for the life of me remember who it belongs to, Pete might know
Like I mentioned, I have an engine set up the same way
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2019 at 9:43pm
I think they did that with alot of older engines
