Poor idle |
Author | |||
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Posted: June-15-2019 at 9:05am |
Need some help please on my 89’ SN with PCM 351. Having some issues with my SN idling and it is often difficult to start and keep running at idle especially after running the engine fast. Runs perfectly at mid-range and top-end. To start it, I often have to pump the throttle nearly wide open after which it produces a lot of smoke (assuming that the engine was flooded?). Used Holley carb that was supposably rebuilt. I’ve set the fuel levels on both sides of carb and tried to adjust the two idle mixture screws starting at 1 1/2 turns out. When adjusting, it doesn’t seem to have any effect on rpm’s or the vacuum when hooked up to a vacuum gauge. I’m hooking the vacuum gauge in place of the PCV valve (right?) as I don’t see another source of full vacuum. Going to check today for possible vacuum leaks with propane. Also, converted to electronic ignition 4 months ago. Read through several of of the threads on this forum and before I tear into a possible carb rebuild (which would be my first time rebuilding this type of carb), is there anything else I should check? Thanks in advance! -Gene
bfootr
One other note- Checking it today, I noticed that it’s dripping fuel into both venturi’s of the carb while idling, pretty significantly. I’m sure this is contributing to my problem but not sure what to check next or how to fix.
William,
First thing to check is the float levels. Since it's dripping fuel, I'd say they are set too high. Another indicator of a flooding condition is you needing to open the throttle up nearly wide open (I'm assuming you are not "pumping" the throttle) Pumping would actually add more gas whereas opening the throttle allows more air in to overcome the rich mixture. How's the choke working both hot and cold? |
Since you've already checked/set float levels, you should be taking out the needle and seat assemblies and cleaning them or replacing them with new ones because they're either leaking due to junk in the seating area or they're worn out.. If you post the list number of the carburetor, it will make it easier to find the right carburetor kit for it. It's stamped on the air horn of the carburetor. An example is shown in the picture. And............after you clean /replace the needle and seat assemblies you need to be sure you have a good filter in the line somewhere or you'll be having the same issue all over again if you have junk in the fuel system. |
Also buy yourself one of the many Holley carb books that are out there
Check the link for some examples You'll learn a lot from any of them. Plenty of pictures and good explanations and exploded views link |
bfootr
Choke seems to be working fine. |
bfootr
Well, guess I didn’t set the float levels exactly correct as I checked them again today and the back float level was pouring out fuel from the level drain. I reset the level again and the issue of the dripping fuel into the venturi’s ceased and engine started idling as it should. Will water test it again tomorrow. Thanks for all the help.
bfootr
The list # is 50463 0909 |
bfootr
Is the carb list # 50463
0909 the same as Holley 4150 or 4160? Want to ensure that I’m buying the right book. |
This would be the Holley rebuild kit in the link below 703-29 assuming the carb is original (no bowl style changes etc) Whether you think you need it right now or not, it would be good to have on hand. Hope you were better at "adjusting" the second time around. link It's a Holley 4160 you have. The books cover a whole variety of Holley carburetors, but they all have sections on basic functioning, theory of operation etc that will give you a good understanding of your Holley carburetor. |
Maybe a picture of this carburetor and what you're doing to adjust the floats would be good
bfootr
Update - After adjusting the float levels, I took it out for another test drive yesterday and it ran perfectly at all speeds including idle UNTIL... after running it hard on our final run, it started to act like it was flooding and was hard to keep idling. Again, had to advance the throttle all the way to get it started. Raised the engine cover and once again noticed fuel moving in the clear sight tube from the mechanical fuel pump. This is the second new fuel pump that I’ve put on since Dec - This one only has only two trips on it since installation. Is this once again another bad diaphragm in the pump? If so, thoughts on what would cause another one to go out? It’s a Carter M60389. Thanks in advance for the help!
Seems so
My 2nd last fuel pump puked two check valves in the same moment and stopped me dead Its replacement had fuel out the vent just prior to my engine work last fall. Form out data points, they don't make them like they used to. Mine were the brandless, two from skidim, one from summit. mIss the original carter, lasted 30+ seasons Appears Fuel Pump is the new weak link on these engines |
Well that sounds like 2 strikes against the Carter M60389. It's pretty hard to install one wrong so it's probably not you causing the problem. As mentioned in your previous thread, there have been diaphragm issues
Where are you buying these pumps, Joe's surplus fuel pump emporium ? You could try for 3 strikes or you could try a Sierra 18-7267 fuel pump. It's a copy of the AC dual diaphragm pump for a 351W and nobody seems to be grumbling about them. The suction and discharge are in slightly different locations. Suction side is easy, but if you have metal between the pump and the carburetor, some bending or a new line would be needed. No guarantees, but I'd go this route before electric. Plenty of mechanical pumps running just fine out there. link AirTex also sells a 60389 which may or may not come from the same place the Carter's do BTW how's the vibration issue from your vibration thread? |
bfootr
HA! Surplus Fuel Pump Emporium...from Amazon. I called Carter's technical assistance line today and it appears some earlier versions of this pump were defective. They are overnighting to me a "new and improved" version (new stock?). Going to try it one more time and if it happens again, will definitely go with the AC version. As for the vibration issue, seems to be much better now. I checked the shaft coupler/trans flange alignment 3 times to ensure it was w/i the .003 spec. Adjusted the carb which resulted in the engine running smoother (outside of the flooding caused by the fuel pump issues) and this has fixed most of the vibration. I think any vibration now is normal as part of the Harmonic balancer as mentioned. I am getting some whining noise at idle at first start-up just in front of the trans but it's not coming from the trans. Maybe the damper plate? Seems to go away when warmed up. Also, leaking a small amount of oil below this area towards the rear of the engine. I noticed that one bolt connecting the bell housing appears to be stripped which may be causing the seal to leak. Will dig a little deeper into this. Slowly getting these issues fixed on this 30 year old girl! Up to the final run last night and the fuel pump issue, she ran like a champ! |
bfootr
Here's a pic of the carb. To set the float levels, I'm removing the float level screws (circled in red) and adjusting the float levels by the nuts and set screws (circled in yellow). until the fuel trickles out of the level ports. |
Assuming they don't want the bad one back, why don't you remove the housing and see what the diaphragm looks like.
A picture would be good. The bad ones seem to have a shiny diaphragm ( a neoprene coating over fabric) that peels and cracks easily. Glad they're sending a new one to ya' |
bfootr
Will do and will post back findings and a pic. Thanks! |
William, There isn't a "seal" between the bell housing and engine. Oil at that point is ether engine oil or trans fluid. What color is the oil? |
I asked about the carburetor picture earlier because the original Holley 50463 would have had internally adjustable floats and uses different needle and seat assemblies than the externally adjustable bowls that it seems like somebody added sometime over the years. The Holley rebuild kit referenced earlier will have the wrong needle and seat assemblies , you can find kits that are more "universal" with both styles of needle and seat assemblies. |
bfootr
It's definitely brown engine oil. |
bfootr
So as long as I reference the List # 50463, I should be able to get the right rebuild kit? |
No, it will have the wrong needle and seat assemblies. I can come up with a number that should work for you later today. As far as the oil, the good news is that your transmission isn't leaking assuming it has red transmission fluid in it. An 89 with the PCM 1.23 to 1 transmission had brown 20 weight oil originally and maybe that's what's still in it. That means there must be bad news though.............the rear main seal on the engine is probably leaking if it's not the transmission leaking. |
bfootr
I think so too. What's involved in replacing the rear main seal? |
Pulling the engine and removing the oil pan. Some have they have done it with the engine in the boat by raising the aft end of the engine so the pan can be dropped. In my mind, that would be a real PITA. |
bfootr
Yeah, I changed the trans oil to the recommended red fluid. |
Don't listen to Pete Your engine being an 89 has a one piece rear main seal and it can be done in the boat without removing the oil pan. Also being an 89 it's normal rotation and a regular automotive one piece rear main seal will work just fine You'll still have to jack up the back of the engine enough to remove the transmission, then the bellhousing and the flywheel. Then you'll be staring right at the rear main seal. It's only a mild PITA |
Well it's later today and here's a number for a Holley renew kit that will have both styles of needle and seat assemblies and all the other parts that you'll need. The number is 37-119. Don't worry that it doesn't say "marine", nothing marine about any of the rebuild kit parts |
Here's a bit of a guideline from another thread
This was to access the damper plate so in addition to what's listed here, you remove the damper plate and the flywheel to get at the rear main seal
bfootr
Thanks!!! I ordered it. Much appreciated. |
