Plywood for trailer restoration |
Author | |||
DockDoc
Senior Member Joined: February-17-2014 Location: Charlotte, NC Status: Offline Points: 474 |
Posted: February-05-2019 at 1:25pm |
Dual axle ramlin... I've been scouring the forums and found some great info. I started teardown yesterday. The side steps are totally rotten, as expected. Fortunately the bunks look pretty good, so going to leave them alone and recarpet.
I've called two local lumberyards who told me 4x10 exterior grade plywood is a nonstarter. One shop told me they could probably find a piece but it would be around $200 (!!). Totally ridiculous. I know diamond plate is an option but I don't really want to outsource, when I could easily do plywood and carpet myself. Any suggestions? I was thinking maybe regular plywood and then get it covered with x-liner or something similar for protection (and leave the underside bare). Also, looks like people generally replace the actuator assembly, anyone ever repair the existing one? Expensive item. |
1993 Sport Nautique
PCM 351w, no ProTec |
bkhallpass
A regular sheet of plywood is like 30 or 40 bucks. It lasts for several years if all you do is throw some carpet over it. It takes and hour or two to remove the old, cut out the new, cover with carpet and reattach. To me, not worth a bunch of extra money.
My $.02. BKH |
Livin' the Dream
DockDoc
I like the way you think. Same logic for the carpet source? I.e. spend $20-40 at home Depot, vs the $150+ ramlin charges for their stock carpet? |
1993 Sport Nautique
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
But a 8’ piece won’t reach. Steps are ~9’. Carpet won’t be easy to install if 2-pieced. Seam will be apparent with any other coating.
stepper459
Senior Member Joined: June-17-2007 Location: United States Status: Offline Points: 349 |
Build it out with teak like a swim deck, oil it regularly, it'll last forever and look awesome.
I've never seen it done.... come on... do it! |
DockDoc
Agreed, but I'm hoping I can find a 10' plywood piece (non-exterior grade) so that won't be an issue. Another option would be to skip the section by the fender / leave that uncovered, and just do the fore and aft sections, which would be feasible with a single 4x8 plywood piece. That's kind of a last resort though.
That's an awesome idea. Can you hook me up with approximately 80 sq ft of teak please? And a jointer/planer and also actually I kinda do want to do this now. |
1993 Sport Nautique
bkhallpass
Been carpeting my trailers for 30 years. This is the first time I'm trying Lowe's carpet. I guess we will see how long it lasts.
BKH |
Livin' the Dream
relake
Senior Member Joined: May-18-2016 Location: IN Status: Offline Points: 126 |
A couple of years ago I replaced the plywood, I went with the 4'x8' sheets, I believe 1/2", my trailer is a single axle. I just made a seam near the guide pole. Yes, it is noticeable, but it doesn't bother me that the seam is there. This was my layout for the steps, bow stop and fender guards.
I did put a few coats of clear polyurethane on prior to carpet. |
DockDoc
I'm reading good reviews on the home depot website, and from people on here.
That makes sense, although honestly if I'm going that route I'll probably just skip the middle portion (behind the fender) anyway. It's completely covered when the boat's on the trailer, and not usable as a step, so doesn't seem like it would matter aside from holding more water and accelerating rot. |
1993 Sport Nautique
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 329 |
Up here in the northland, I ordered some of this marine grade from Menards. I see now they have it in 10 ft lengths. Using this you would probably never have to replace it again. I have used this stuff over the years for boat seats and outdoor projects that are outside all year and some have been out there for 15-20 years without falling apart or rotting. 1/2" is only $58 per sheet not on sale. |
Martin, Do you understand what marine plywood is? It has NO treatment for exposure to moisture. It simply has very tight control with inner ply voids. What is marine plywood What you purchased is NOT marine plywood. note the BS 1088 standard Menards can call it what they what to con there customers. Sorry but if it wasn't stamped as meeting BS1088, then it's not a marine grade. |
Martin,
What did you coat the Menards ply with? Did you happen to notice these statements in Menards product description? "Not treated against rot and decay like pressure-treated plywood" "It is considered a premium panel-grade ready for sealing for use in high-moisture applications" |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10754 |
Gotta admit Pete............your bedside manure is impeccable. I didn't misspell any of those words either |
DVskier
Well at least Pete didn't call him "a backyard hack". He's lightening up a bit in retirement.
Working with lumber and wood boats for many years, I get pretty upset with the misconception out there as to what marine plywood actually is. I feel Martin may be a example of this misconception and then going to Menards where I guarantee no one explained to him what he was buying.
So Ken, per your comment it sounds like I shouldn't say anything and let other people fall into misusing marine plywood? My intent it to try and stop the spreading of manure. |
DockDoc
Cool so... Regular plywood? This backyard hack is still a bit confused.
1993 Sport Nautique
Can you use something like starboard or is it not strong enough?
So Pete is trying to say raw marine plywood isn't appropriate AND the menards stuff MAY not even be marine plywood. Is this true?
$80 is a good price for any 10’ ply around here... the low grade “marine” usually gets you more plys and fewer voids which is a bonus if true. Even if not that’s still a good price.
How about 1x4s treated. Run them front-back. Cover with carpet individually. Will take extra carpet & staples but that is pretty cheap. Could leave some gaps to allow easy drying for that matter.
Orlando76
As mentioned already this is a fairly simple task and cheap to do again in 5 or so years. New wood and carpet. Regular ply and cpes if it makes you feel good and voila. It’s not like it’s the floor or uh “sole” for Pete’s sake or even worse, stringers. Just simple running boards on a trailer that’s are always accessible.
Orlando76
$150? Might want to recheck that or speak to someone else. I paid about that to have Ramlin replace my step boards entirely, wood, carpet, labor, TTT OTD. |
gt40KS
Feel like I need to interject a 2 cents as well. I too have worked with woods for years - most of my life really. In fact, it's my business. When I was doing all the work on my boat last year, I had noticed that Menard's advertised 'marine plywood' in stock and went to get some for several of my interior projects. What I found - even though it was labeled marine plywood - in my opinion was not marine GRADE plywood, but as Pete has suggested a type of higher grade plywood, perhaps with no internal voids. But IMO, this was not marine grade, chemical treated waterproof (resistant) plywood. Reading the very limited information, and asking sales associates about their product, I couldn't find any information indicating this plywood was even exterior rated. I've purchased marine grade ply in the past, about 12 or 15 years ago, and if memory serves $80 for even a standard 4x8 sheet would have been a great deal back then.
Having said all that, I frequent Menard's for a lot of various materials from time to time and for the most part I'm impressed. There are several positive things about the company and their products that they don't tell you nor outwardly advertise. So perhaps a little latitude could be given, at least until proven otherwise. And having said that .... If I was looking for plywood that, ideally, needed to be waterproof, I would most probably opt out of the Menard's stuff unless or until it had been verified. |
JCCI
1995 Ski Nautique GT40 |
Ext. grade with at least one side "B" if you want a smooth surface. Then plenty of CPES especially on the edges. |
Read the BS1088 standard I linked. ^ It is not "chemical treated waterproof" |
Yes you could but if it is Starboard, you can't glue carpet to it. It's HDPE. Staples only. |
Pete It looks like maybe you should straighten out the APA (The Engineered Wood Association) They seem to have a definition of what qualifies as marine plywood, see the link below link You have your BS 1088 definition that you think is the only one out there but like most things there are different definitions and standards. Maybe instead of telling Martin he may be an example of a misconception you should explain why you feel your BS-1088 stuff is better than his.. While you're at it, you could straighten out the Home depot people next time you put the apron on. They sell the same Roseburg plywood that Martin linked with the same wording in their advertising. Must be the same con job.as Menard's . Then you can move on up the wood chain and make sure those people at the APA are all properly educated too. so they're not pulling the same con job. After all that you shouldn't be upset any more |
rosconole
I need to do 2 trailers I was thinking about .125 aluminum treadplate, same thickness they use for fire trucks... its a little more but problems no more...
Ken, Your comprehension.is typically great but this time I ask you to re read |
Yup, must be lousy comprehension so you'll have to spell it out Pete, what's the misconception? What should I be re re reading? The stuff works for Martin, it would work for the trailer too. One of many things that would work. Now tell us why APA marine plywood doesn't get the Pete's good wood seal of approval and it's a con job.. |
