Steering cable length '68 Mustang |
Wilson_1968
Newbie Joined: November-24-2018 Location: Oswego, IN Status: Offline Points: 23 |
Posted: January-12-2019 at 5:36pm |
Greetings. My boat did not come with steering. I am ordering new parts and wanted to make sure I'm correct in ordering a 13' steering cable. I hope someone can provide advice regarding this length. I learned that the cable runs along the inside of the stringer, under driver seat, then takes a swooping left bend into the helm (horizontal entry). Looking for any tips on getting the cable under the seat and through the motor compartment. I'm thinking I feed from the rear. Is that correct?
Also, I shopped online but don't know if I can share the company on this site (etiquette). Nonetheless, if you have a favorable vendor(s) for all parts including steering, pls share if allowed. Gracias. Looks like I'll be dropping about $370 for clevis hardware, clamp block with ball post, support tube, cable, bezel and helm. Reasonable? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10755 |
Etiquette...................... unheard of on this site
If you don't post places you're dealing with, how can you get any feedback on service, prices etc? You'll get opinions on everything, some totally biased, some not And if you don't post part numbers you won't get any feedback on whether you may or may not have the right parts all figured out. in your previous post from November, there seemed to be some question as to your engine size. Did you ever figure out whether it's a 302 or 351? |
Hope your looking at a SeaStar Big T helm. Correct Craft originally used Teleflex Big T but they have been sold since those days. Some here will say to use a 16 foot cable,mine was a 17. Go2marine used to have the best cable prices but that has been awhile,you'll have to do a search
93/70 ccpb
Senior Member Joined: March-05-2006 Location: United States Status: Offline Points: 448 |
do you have steering wheel?if you want to go used i think i may have everything,bezel will need to be rechromed,let me know and ill dig it out of storage.they are original parts off a barracuda.pm me
Wilson_1968
Thank you all for posting, and as always, it's an interesting read.
KENO, no I never did because it was mentioned that the 351 wouldn't fit under my box while someone said it would with some grinding. It became less of a priority since I'm going to pull the motor and I'll be able to see casting #s quite easily, u c wum sayn? The topic of this post is cable length and cable routing however. Can ya hep me with those questions? I appreciate your candor on etiquette, go2marine is the vendor and they want $213 for helm, bezel and cable (Part No. 159320) and $158 for clamp block, ball post and tube (Part No. 115525). BTW, since you're still on my prior post, I did gettr all titled and registered, woot! She's in the roles as a '68, woot! Appreciate all the responders on that one with pics and all, learned a lot. Thanks Gary, Sure seems like 16' - 17' would have lots of excess. Total length of boat is only 16' I guess that makes the swooping bend even larger eh? Is my routing of the cable and feed into helm correct? ccpb, thanks, I'll pm you. |
Well, you didn't ask but here's how to easily in under a minute or so tell if you have a 351 or a 302. Terrible etiquette on my part
See the picture below and measure across the intake from the mounting bolts on one side to the bolts on the other side. Centerline to centerline is about 9 1/4 inches on a 351 and about 7 1/2 on a 302. I'm no help on the cable length and routing for your particular boat. |
Gary is correct. The rule of thumb for the era is 1 foot longer than the boat length. Yes, you want a swooping bend. The tighter the bend, the more bind on the cable. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
16’ cable for a 16’ correct craft... have done many of them. 13’ would end up a few feet short with the factory routing. Cable itself should be $100. Post pics of your routing, it doesn’t sound quite right.
Wilson_1968
Oh wow, that was easy, thanks Keno, I'm a 302.
Looks like the 16' takes, thank you for all the replies. TR I don't have a pic of the routing, but here's a pic of existing ball post that's on inside of starboard stringer. Cable runs along stringer up to front of motor where it crosses over to to underside of driver's seat, then swoops into the helm. I'm thinking easier to feed from rear, but got no clue honestly. Cable was missing when I got boat. |
Only sorta easy If the boats a 68, there's a good chance it's a 289 Back in your other thread there were questions as to whether it was a 68 or 69. Either way, with the skinny manifold it's a 289 or 302 Back to the steering cable discussion now |
This is what we need to see. That description and the mention of a 13’ cable sound very wrong. |
Wilson_1968
10-4 on ruling out the 351, ty.
TR, I don't know and have no pics or diagrams is what I'm trying to tell you all the way back to the op. After several replies I admitted that it looks like cable needs to be 16'. As far as routing, and where the ball post is located, and what I discussed offline, it appears cable goes as I've explained. How would you route? Surely, several of the members here know the routing of this cable. |
Why don't you make a hand drawn diagram and post it here instead of trying to explain how you figure the cable runs? u c wum sayn?
You could use the instructions for determining cable length that are on the Go2 website to give yourself that warm fuzzy feeling about a 16 ft cable. Use a rope or plastic tubing to figure out the length One thing about your choice of steering cable. That Go2 marine part number is for a No Feedback cable. You don't want one of those for your inboard steering. It's good for big outboards and IO's. Not so good for an inboard Look at part number 157049 from Go2 marine. It's a 16 ft cable and it's 132 bucks with helm. cable link You must be planning on only using part of that transom mount kit for an outboard too. And............stick it in from the rear. Feed a rope or some plastic tubing thru first and then tape or tie the cable to the rope/tubing and pull it thru. |
Can’t imagine there aren’t a hundred pics of the correct routing here... I can’t follow your explanation to know if you’ve got it understood.
SSC6116 = $111 at go2... if using the original style big-t helm. https://m.go2marine.com/product/74213F/qc-ii-replacement-steering-cable-ssc61.html |
He's probably gonna tell ya he don't have a helm from the looks of the picture in the first post
Then again, maybe it's in a box somewhere |
Wilson_1968
You boys r the best, wum sayn? Thanks for the tip on the no fb cable.
