Overheating 1989 SN |
djenns13
Newbie Joined: July-25-2018 Location: New England Status: Offline Points: 7 |
Posted: August-22-2018 at 10:36pm |
So I've replaced the impeller, got a new thermostat, checked the raw water filter, and replaced all the hoses from where the water would pass through the system. I was curious if anyone has experienced similar issues and been able to find a solution. I've hit the engine with an infrared thermometer but it will give low 100s and the temp gauge will hang around at 170 for a little then jump to 180. This is all while in motion, but no tendency to spike when at idle. I tested the thermostat as well and its functioning properly at the 140 degrees its rated for. Let me know.
Dan |
Are you saying the IR thermometer indicated 110F? If so, your engine is not overheating, your gauge is inaccurate. Someone else on the site had this same problem recently, I believe it was a wiring or ground issue. |
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Chances are you have the infamous voltage drop/ weak dash ground and you’re not overheating. Run a jumper ground wire from the temp gauge to the negative battery terminal and see what it does.
You will likely need to run a new dash ground to the permanently solve your issue. If you search the forum, there are many threads about this and how to fix the issue. |
1989 Ski Nautique 2001
djenns13
Sweet thanks, currently waiting for a replacement trans cooler as the one on the boat appeared to be bent, if that doesn’t fix it I think the wiring is my next area to attack.
And positive feed besides the negative. |
