GT-40 Performance Upgrades Help |
Post Reply | Page <123> |
t.franscioni
Groupie Joined: February-13-2015 Location: Salinas, CA Status: Offline Points: 68 |
Yes I get that. Just a little sarcasm on my part.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
Hey Thomas, I've been reading on the other site as well, very interesting discussion even if a bit over my head. As a GT-40 owner I appreciate all the work to find solutions to the ECM support issue.
Yes, we get a bit off track at times here, but it generally is something useful like an electric connector discussion, I've learned a ton on this site. I've been looking more and posting on the other site lately, enjoy it and it's a different group and different discussion so interesting to spend time on both. |
t.franscioni
Agree 100% . CCF has a better sense of humor though in my opinion.
lewy2001
Tom I used this kit but it previously came with a new ford connector.
https://www.diyautotune.com/product/diypnp-ford-60-pin-eec-iv-unassembled-kit-no-connector/ I have since moved the ECM up under the driver side dash panel. With an extension cable I manufactured. I think one of the reasons the original PCM GT40 ECM's are starting to fail on these engines besides age is the amount of heat cycles they have endured under the engine cover. I verified the logged ignition table at a few points with a timing light and then transferred those values straight into the Megasquirt ECM. The fuel table required quite a bit of trial and error. In fact I am still adjusting it, that is part of the fun. When Adam and Tim visited last year there was quite a few back to back barefoot runs that showed I was a bit too fat on the top end of my table. Previously I had hardly ever used that section of the fuel table. Being able to log and then re tune makes this a fun project that just keeps giving. Hey I may even add that stroker kit so i can start all over again. If you decide to go with the Megasquirt I can supply you with my tables. The block for the O2 sensor was the one Alan had made for his 81 when doing engine upgrades but never used. He kindly sent it all the way to Oz. I made up a elbow to get it further away from the wet exhaust if the O2 sensor failed but it has not been required yet. |
t.franscioni
Very cool. Ya that's about 80% of the reason I want to do a megasquirt for my GT40... should provide for many future hours of tinkering time on the lake and in the shop. Note my email T.Franscioni@icloud.com if you could send me the tables or tuning file whatever you got that would be awesome. Iv never tuned an EFI system before so it would be nice to have some good info to load onto the megasquirt to get me going and then in meantime I can begin working on tinkering with data logging and making adjustments and experimenting for fun.
jbear
yup...scotchlocs were the boss Gary....but they sure helped to cut down on our overtime! Had to laugh remembering the twist and the little cloth tube. Was cleaning out the attic getting ready to move and found a box of 1000 'beanies' or in your lingo...'pumpkin seeds. sorry Tom to be boring you........ john |
t.franscioni
No no go ahead....I'm just a groupie
Rlbarrasjr
Newbie Joined: July-27-2018 Location: 70122 Status: Offline Points: 9 |
Lewy2001, sent you a pm... any info you have on your megasquirt setup would be appreciated. I'm considering the same conversation and maybe setting up closed loop scheme. rbarras@gmail.com
This is an old thread but it started with someone looking for more power out of a 351W GT40 engine.
I have not read anywhere on here of someone installing a set of AFR heads. There are some trick heads out there developed for the Mustang market but they out flow a GT40 by a fair amount. More flow = more HP potential. I saw a set of AFR 185 heads on Craigslist slightly used for $1,100 and I was tempted to try them but my GT 40 runs so well I am reluctant to play with it. I think they could run 40 HP stronger than the GT 40 heads. |
Rlbarrasjr
I helped Thomas awhile back with testing the GT40 replacement computer options. I will be doing power adders at some point on my boat. I have done the research on the MEgaSquirt, but I'm also exchanging emails and working with the guys that support Ford EEC-IV Binary Editor and TunerPRO to get a definition file made to tune the factory PCM GT40 computer. I'll post any info I receive.
If you can break the code and come up with a not super expensive way to add power to the GT-40 you will be a hero to a lot of people on here.
I’ll be watching this one |
anm2254
Newbie Joined: November-09-2004 Location: United States Status: Offline Points: 9 |
Are all GT40 heads the same?
Can I use a Mustang/explorer set on my 86 Martinique? |
Yes all GT 40 heads are the same. Hard to find and usually costly due to 5.0 guys using them. Came on 5.8 Cobras,Lightening trucks, and of course GT40 boat engines. GT 40 p's came on 5.0 Explorer's and Mountaineer's are more common. Exhaust manifold fitment issues on cars but no troubles on marine. You would need brass freeze plugs installed and the head bolts drilled out to 1/2". Actually marginally out flow GT 40's and are the best stock production Ford heads.
Rlbarrasjr
It is done!!! Core Tuning compiled a definition file for the 300m marine gt-40 using their Binary Editor Software. I was emailing Clint and Ben for months to get it ready. This can also be used on earlier e290 ecus. I just got it loaded. Going to do some test using the QuarterHorse Chip in the coming weeks. The definition is MCSR1. There are way more parameters defined than what i expected. see screen shot. It is supposed to be able to datalog too. |
gt40KS
Awesome! Let us know how things progress. Seems it's been a good year for current GT-40 owners
JCCI
1995 Ski Nautique GT40 |
DHMcFadin
Senior Member Joined: May-27-2019 Location: Austin, Texas Status: Offline Points: 312 |
Any updates to the GT40 Performance Upgrade?
Rlbarrasjr
it all works. Get a quarterhorse package from coretuning.. http://www.coretuning.net/
Email Clint first (Clint@eecanalyzer.net) before buying to make sure he knows you need the MCSR1 definition file. remember this is all DIY tuning. If you need help with the actual tuning itself for whatever mods you made i recommend reaching out to Adam at pops racing or Mike with efidynotuning. http://www.popsracing.com/services.html http://www.efidynotuning.com/ |
t.franscioni
Rusty
Using that MCSR1 strategy you can view BOTH the 300M and E290 tune? Or is this MCSR1 just for the 300M? Out of curiosity I’d sure like to compare and contrast the two tunes and see what changes PCM made. |
Did this upgrade just allow you to get a dead ECU running or are you putting more ponies to the water with the tune?
Rlbarrasjr
yes.. the MCSR1 strategy will open both calibrations, but i wouldnt use e290 at all. the 300m seems to be a more mature calibration.
Biggest thing to notice it that they drop some spark and richen up the upper rpm range. they made some adjustments to lower/smooth idle too. |
Rlbarrasjr
here a google sheet to all the differences
https://docs.google.com/spreadsheets/d/1U3fmH4CpZZruHfRYuz6SNfSReoY2ZpM-O8wOg5WmV6M/edit?usp=sharing |
Rlbarrasjr
both! sort of. the dead ecu replacement with the chips that places are selling are taking this same family of hardware and loading a stock tune/calibration on it to get up and running. this software addition will let you manipulate/tune that stock calibration file for any performance upgrades you do. it also does datalogging. personally i plan to put a stroker rotating assembly in mine and i'll need to tune for it. |
t.franscioni
[QUOTE=Rlbarrasjr] yes.. the MCSR1 strategy will open both calibrations, but i wouldnt use e290 at all. the 300m seems to be a more mature calibration.
Biggest thing to notice it that they drop some spark and richen up the upper rpm range. they made some adjustments to lower/smooth idle too. Very cool. Thanks for taking these next steps this will undoubtedly come in handy for people. I like your stroker plan. Make sure and do a write up of that mod. |
Personally I would go roller cam, roller rockers and a nice set of AFR heads then see how it tunes, that combo should put you close to the 400 ponies mark. |
DHMcFadin
Does any know what years pcm used the e290 and 300m calibrations? I have a 99 GT40 with the original ECM.
I have a engine with 1998 date codes on some components - it has the 300 tune.
t.franscioni
Talking to people and helping program chips these are the years/tune revisions Iv come up with. Correct me if I’m wrong.
95- 58HO tune 96- 290M tune 97-some 98- E290 tune Some 98-2002- 300M tune |
If you read the sticker on your ECM you'll know what you have for sure Here's a picture of a sticker |
Tom my May of 95 SS has the 290 in it
DHMcFadin
Thank you! I appreciate the picture!
