  New Posts New Posts RSS Feed - Starting problem
Starting problem
Brock7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Topic: Starting problem
    Posted: June-17-2018 at 6:22pm
I have a 96 Correctcraft Sport Nautique that has about 350 hours on it. We took it out and had 4 people ski without any problem starting the engine. After we took a little break the boat started and quickly petered out. The engine then wouldn’t start but it would turn over and sound like it was about to start and then wouldn’t. Any idea of what is wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 7:42pm
Does it have Peo-tec ignition? They are known to fail with heat soak.
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 7:56pm
Which engine model ... GT40 efi or carbureted ? Ford or Chevy power?
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 8:18pm
It is a Ford 351 PCM engine so it is fuel injected
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 8:28pm
Just to start simple...................is your safety lanyard plugged in or did it maybe get knocked loose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 9:24pm
The safety lanyard is plugged in
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 9:53pm
Less simple ..............can you hear the fuel pumps run when you turn the key on?
You can read about fuel pump and ECM relays in this thread in the link below.
Either relay being bad will keep the fuel pumps from running
If you look at the diagram in the link you'll find breakers for the fuel pumps and ECM that you can check too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 10:26pm
Got gas in the tank ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 12:09am
There is plenty of gas in the tank and I can hear the fuel pump when the key is turned
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 12:38am
Got spark?
We're still on the easy stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 12:57am
got a service manual?
Click the link and you will.
301 wonderful pages of reading.
You could spend some time reading this thread too
Poor man's GT40 diagnosis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 1:24am
Yes we have spark we also replaced the spark plugs last fall
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 2:25am
Brock, when the engine died you said it "quickly petered out". Did it surge and almost die and surge again, or did it just start, run 5 seconds, and die? And, did you again try to start it hours later once it had completely cooled down?
On the kill switch lanyard question - it's worth removing the lanyard and holding the switch in all the way with your thumb while trying to start, just to make sure. I had a lanyard that just barely engaged the switch, then didn't quite engage it, had to change out the switch.
vwg98sn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vwg98sn Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2018 at 2:55pm
From what it sounds like, you need to replace the ECM relay. Very same problem with my 98 gt 40. Very inexpensive to replace, and easy fix.
With key and ignition on, you can try tapping on the relay and listen for a "buzz" of the fuel pump to charging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 1:29am
We are all assuming at this point that you have the GT40 engine since you say it is fuel injected. Just to be clear, CC had at least a couple of Ford options for several years in the 90's, one of which was a 260hp carburated 351. The only one (Ford 351) to my knowledge that was fuel injected in 96' was the GT40:
GT40
Any updates on progress?
JCCI
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 8:28am
Brock 7 hasn't logged on since 6/18 Joe
Maybe he figured this out, maybe he didn't.
Maybe he's halfway through the manual.
His replies were just chock full of info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 10:07am
Maybe he took it out again
Could be still out there stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 10:42am
Yes, and needs a rescue?
BTW, does anyone know who this is? One of us???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 10:50am
Looks like something Larry would create
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 11:06am
Gary,
That did cross my mind but there are too many details that look real.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 11:33am
Gary,
Looks like the real thing!! White River near Broad Ripple Park Indiana
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 11:50am
Looks like the real thing!! White River near Broad Ripple Park Indiana[/QUOTE]
Zach's stomping grounds
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 1:04pm
Oh, they went over the dam. I thought they were headed upstream, just needed a few more ponies to get up and over!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2018 at 8:11pm
An anchor would have been helpful there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brock7 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2018 at 5:34pm
I can here the fuel pump buzzing without doing anything so does that indicate whether or not that needs to be replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2018 at 6:07pm
Brock,
Have you had a chance to take a look at the manual and the gt40 diagnosis thread?
Yes, more details would be great so we can try to help like the fuel pressure at the rail?
