  New Posts New Posts RSS Feed - Do I have the correct prop???
aucade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Topic: Do I have the correct prop???
    Posted: June-08-2017 at 12:20pm
Hey Guys,
This is my first time on here. Thanks!!! I have a 78 Ski Tique with the Ford 302. I have a bad vibration while running and swapped the prop to find the vibration disappear--Great--easy fix. But before I dump money into prop repair--Do I have the correct prop???
The boat will be dual use wakeboard/ tubing and cruzin with the fam. The prop I have Is a Columbian Hydroflite D13 x P14R 3 blade nibril prop. Is this a good prop for my needs before I repair it? It was better out of the hole and top end than the beat up 4 blade I have on it now. Thanks again guys.
1978 Correct Craft Ski Tique--Ford 302
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 12:49pm
Nope 13" diameter is too large for the Ski Tique hull. Original prop would have been a 12x14 Federal. More modern replacements would include the 12x13 and 12x14 OJ 3-blades, as well as the 1210 Acme (12.5x12 3-blade). The 1210 is the best performer of the bunch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 2:07pm
I found a good deal on an Acme 1210, will I loose top end with the 12 pitch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 2:20pm
Not typically. I certainly wouldn't expect as much compared to the less-than-optimal 13x14 you had on there.
Prop size (pitch diameter and cup) are not sufficient to compare props from different manufacturers. An Acme 1210 does not act anything like a 12x12 Federal... more like a 12x13 or slightly larger based on the wot rpm a 4bbl 302 in a 16' Correct Craft will pull them. Holeshot, midrange acceleration, smoothness, etc are all vastly different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 2:49pm
so based off of my description of how I plan to use my boat with at least 2 large adults and 2 kids both cruzing and wakeboarding the acme 1210 would be the best choice?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 3:00pm
heh, pull the trigger on it already, summer is short!
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 4:01pm
What price and where for the 1210?
Delta propeller - site sponsor
$364.00 - 5% + free shipping
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 5:29pm
I bought a prop last year,I think I got 5% off from them. Can't find the discount code on here either. They still were the cheapest around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 5:43pm
Delta's ACME buying power is undoubtedly strong and they seem to pass that on to the consumer. I have still not seen any retailers come close to their prices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 7:16pm
I paid 379.99 out the door with free shipping from WakeMakers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 8:44pm
Can't find the discount code on here either. .
The Delta Prop Discount Code is on the Deltaprop.com banner at the top left hand corner of this site. It is DP5CCF08
FYI,
Donald
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 9:01pm
FYI,
Donald
Gary,
You're getting as bad as me!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2017 at 10:13pm
Not coming up on my laptop must be the browser I'm using. I can see it on my phone right now though
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2017 at 12:36pm
Should have listened to us, you could have saved 40 bucks
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2017 at 10:32am
yep, !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aucade Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2017 at 7:00pm
Ok so I purchased the Acme 1210 and installed it the other day. OMG!!! This this thing is a rocket!!!! I am astounded in the increased performance over the 4 blade beat up OJ prop that I had on it. I seriously doubt you could hold onto a ski handle if I I punched it out of the hole. This thing is awesome. Thanks to TRBenj and everyone who pointed me in the right direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2017 at 7:40pm
Another satisfied customer! Glad it worked out for you.
