  New Posts New Posts RSS Feed - need help identifying this Correct Craft
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 7:25pm
Rick,
Get some volt readings at the battery (on the posts - not the cable terminals) and then all the way through to the starter during cranking.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 8:11pm
something doesn't sound right with your timing... that battery could be weak, but if you can make the motor spin with the starter by retarding the timing, it sounds to me like you have a plug out of order, or you have #1 180° out.   Make sure you have #1 it on the compression stroke when you mark the distributor, location of #1 wire doesn't matter, as long as the rotor points to the plug wire in the right order.   Since you have a Mopar, make sure you are actually putting #1 where it should be on the motor as well.   Ford/Chevy are different, so double confirm...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 8:22pm
Here is a diagram for you - pulled from another site, but it looks to be comprehensive.   Also to note, the distributor is shown in a schematic location, your dist. looks like it is in the back of the motor by the flywheel...   This Schematic diagram looks as if the dist is in the front of the engine... cylinder location is the same, compared to the flywheel, the diagram is just a bit confusing.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:03pm
Originally posted by backfoot100 backfoot100 wrote:
If you're going clockwise around the dizzy from #1 that firing order is for a Chevy.
I have no idea what a RR rotation Mopar firing order is or which way the dizzy turns in that scenario but I would be really surprised if it's the same as a bowtie.
It's time for your really big surprise now Eddie.
Small block Mopar firing order and cylinder numbering scheme is the same as a Chevy.
The distributor turns clockwise for both normal and reverse rotation, the same as a Chevy too
For rilee29, with the distributor cap off look at your rotor and see which way it's spinning when you're cranking the engine over. If the rotor is going clockwise you've at least got the right starter.
If it's going counterclockwise.......it ain't gonna start no matter what order you use.
It would mean you have the wrong rotation starter in there.
Edit Chrysler's LM designation is for a marine engine
Hope this helps you some
KenO
Thanks for the info Ken. Much appreciated. Chrysler and Chevy engineers had to be working together,...LOL.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:21pm
Originally posted by rilee29 rilee29 wrote:
I am starting my firing order with #1 on the cap in the middle pointing at the carb. Clockwise, 12756348.
...anyone see something I'm not?
Firing order is reversed.
Need to verify which terminal on the cap is truly #1. It could be any of them. Get to compression stroke of #1 cylinder and see which terminal the rotor is at. That's #1. and CW from there. 18436572
Thanks again Ken...
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:28pm
Or is the firing order truly reversed even if the dizzy spins the same direction for RR engines??? Wow, I feel like friggin' rookie here.
Guess that's why I stick with standard rotation engines.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2016 at 10:57pm
He needs the reverse rotation firing order which is how he says it's hooked up now.
That would be 1 2 7 5 6 3 4 8.
And rilee that LM designation just means it's a Chrysler marine engine and tells you nothing about direction of rotation although it certainly seems that you have a RR engine based on your rotation observations.
Like Eddie and DesertSkier I have the feeling you haven't correctly found TDC for #1 cylinder and then oriented the distributor wires so that the terminal the rotor is pointing at is by default the terminal for #1 spark plug wire, then go clockwise from there with the Reverse rotation firing order..
Just a feelin
KenO
rilee29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 1:14am
think I have found it. Firing orders and plug wire orientation were correct. I had spark, but was checking it at the coil. Turns out somehow my distributor is shorting out. I can light my test light on the outside casing. more old time checking I had forgotten about. Any recommendations for a distributor upgrade that doesn't cost more than the $500 I paid for the boat and the extra $500 I have put into everything else so far?
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 10:02am
Sounds to me like a good inspection of the distributor wire from the coil negative terminal where it enters the distributor and replacement of at least the points and condenser would maybe solve your problem.
And making sure you have a distributor body ground to the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 10:42am
Yes, I have found this wire frayed where it goes through the distributor body causing a continuous grounding of the coil.
I also suggest taking a step beyond the test light and getting a VOM. Inexpensive meters are around $25 and will tell you much more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 2:08pm
So maybe my ignorance is showing out a bit here, but I have never heard of having a distributor body light up a test light before.    How can that be possible?     Seems to me that the light would flash on momentarily if the spark was jumping to ground if there was a problem with the internals of the distributor, but that would also suggest that touching the distributor during cranking would give you one nasty surprise.   If the light lights when standing still (which is what it sounds like to me from your description above), I might be tempted to think your battery positive and negative are reversed...   If the positive was going straight to the engine block, it seems like you would get this result.   Since this is an old boat without electronic parts, You might be able to do a positive "ground" without having to send parts back to the factory to have the smoke reinstalled .    Seems like this would make the starter spin backwards too and without having much power.   If I am totally off base, I would love to be educated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 2:14pm
Kris,
It's got me confused as well. It's got to be the way Rick described it??
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 3:02pm
Kris,
i could say something like "this should be intuitively obvious to the most casual observer" but I'd be lyin".
It wasn't much of a description of how he did this, but it's coming from the battery one way or another.
I guess he'll probably have a better description coming along soon though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 3:36pm
Rick,
The body of a distributor is grounded to the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 3:55pm
I'm still struggling to understand a bit of it myself. The points and condenser are new. They were installed by the previous owner who owned Taylor Marine in Salt Lake. Obviously the smart ones had trouble too. I bought a new coil and ballast last night and that's when I noticed the magic leaking. Test light lighting was an accidental find but in any case, everything got shut down. I know power to the casing should not happen so I am looking for a electronic conversion plate for the distributor. I hate hunting down 50 year old problems. Off to the parts house again......btw...I have a wiring schematic so wiring has all been checked by me and another person for correctness. I'll post later when I find parts.
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 4:25pm
Rick,
When you're out, get that VOM so you can do some decent testing and not just start throwing parts at it. We'll guide you through it.
When you get that test light to light up, where exactly are you touching the probes? Also, is that with the ignition switch turned to the run position?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 4:49pm
Test light was resting about an inch from the distributor wire on the case when I turned the key to the run position. Within seconds I started to see smoke at the ballast too so I shut down and disconnected the distributor wire. Everything was OK then. I assumed the wire was shorting internally in the distributor. I have a dvom. You guys are awesome to even take the time to brainstorm with me! Thanks a ton!
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 12:18pm
so patience does pay off! On a classified add site yesterday and snagged an HEI conversion distributor (brand New) for $50. Any comments pro or con to using one of these? Seems like a great idea me being a GM guy. I am hoping to create some confidence and longevity in this boat running and not leaving me stranded....lol Besides, I can take back the $63 in parts I just bought for the old ignition system.
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 12:55pm
Well sooner or later somebody will ask if it's a marine distributor so it might as well be sooner like right now.
Is it a marine distributor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 6:21pm
If you do have a Reverse Rotation Motor, the gear on the distributor will have to be different for the Reverse Rotation. Maybe you are planning on this.
I grew up with a 72 Martinique with a Ford 302 Holman Moody motor that my Uncle owned on White Lake NC. They sold the boat in 1980 and I would love to find it, but I probably need to be careful what I hope for.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 6:27pm
Originally posted by Donald80SN Donald80SN wrote:
If you do have a Reverse Rotation Motor, the gear on the distributor will have to be different for the Reverse Rotation. Maybe you are planning on this. .
Yup, it's a RR:
So the starter spins the motor ccw.looking at it from the front. .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 7:13pm
Is your distributor branded DUI?   several guys have converted to them, and they seem to be a good alternative to standard Distributors.   I hope it all goes well for you.   Post up some pictures of what you picked up
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 7:40pm
A 318 Chrysler doesn't have a gear on the distributor, the gear stays in the engine and there is a slot on the top. The end of the distributor shaft has a short male stub on it that fits in the female slot. Kinda like..........well never mind. Bound to get some comments on that description.
KenO
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 7:48pm
Ken,
Just so you don't have to further describe male shafts fitting into female slots, here's the picture:
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 7:53pm
How do i get pictures on here from my phone? Cut and paste option doesn't seem to exist?
Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 9:18pm
Ken,
Thanks Pete
You could have at least shown a marine distributor though
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 9:35pm
Ken,
Thanks Pete
No problem Ken.
I did try to find a picture of a marine but none I could find showed the shaft end. For those who may not know the difference, the one shown is an automotive since it has a vacuum advance. It's the round diaphragm chamber on the side. Marine units are mechanical advance.
Chevy350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2016 at 9:36pm
Well its easier to do on comupter, but click on the tree with the up arrow, then choose the picture you want. Like I said it's easier to put the photos on your computer and upload load them from there.
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 2:08pm
KenO
Wow, I did not know that. Very cool.
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote rilee29 Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2016 at 2:30am
since I am not savvy enough to do the pics, the distributor is a Proform part # 67040. I installed it today and we have the baby breathing again! Sounds awesome! I am pretty sure the block is a reman, but with the HEI and the 750 Summit carb, it is very responsive. Had to rebuild the water pump today also. I don't seem to be getting the water flow where it should be though. I am using one of those plunger looking gismos on the underside of the boat . the attached hose goes to both the pump inlet and the oil cooler. I have seen some pretty clean looking setups on the internet and tried to make sure mine was the same, but who knows if they are correct....
Rick
