  New Posts New Posts RSS Feed - mustang #1 pictures
mustang #1 pictures
 Post Reply Post Reply Page    <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 11:09am
Originally posted by BuffaloBFN BuffaloBFN wrote:
Pete, are you bustin my chops again?
Not at all - it's what you had to do to find the Doug Fir in your area. I however do feel that your dads high end staircase background rubbed off on you! That's NOT a bad thing and is certainly evident with your skills!!
BTW, I've got to stop at my hardwood lumber again for some more White Oak. I screwed up ripping the 4th spray rail I'm making for my X55! I'm making 2 for mine and 2 for Craig (64X55). Ripped the shape to the narrow dimension of the bevel instead of the wide dimension. I got sloppy on the 4th piece and wasn't paying attention!
farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2009 at 8:01pm
Ok,thanks Pete.I'll pick out some nice pieces at the local lumber yard. We have a couple of small scale lumber mills in town and one of them has a kiln and moisture meter.I'll shoot for 8% or so.I suppose the kiln will warp the boards if they are prone to do so. That will help.I can find out before I cut them.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2014 at 10:39pm
Got in a good day at the mustang.I had the floor pieces cut out for a couple of weeks but I was busy working on the seats until I ruined my last sheet of plywood.So today was spent fitting the pieces. Here are a couple of pictures of my progress.
The short secondary stringers are not glassed in yet so the starboard side are not staying where they are in the picture.Now I can coat with smith's penetrating epoxy.
Tomorrow I will get another sheet of cdx for the seat bases so I can get all that stuff to the upholstery shop.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 10:50pm
I'm finally getting around to posting some pictures of my progress on the mustang 17.It's not done by any means but I did get her in the water for some fun before it get too cold.
I had the back of the hull on wheel dollies and the front was on the engine hoist. I was able to get it out of my workshop by myself. I then took the wheels off of the trailer so
it was low enough to slide it under the boat.Back on the trailer after all this time..
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 10:57pm
I put the carpet in on the floor only to save time
That was my first experience with carpet.It wasn't too bad but i'm not sure how to make the joint between floor and sides.
By the way I used the Rustoleum garage floor epoxy for the bilge.It covered good with one coat and seems to be really hard.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 11:05pm
My buddy came up with his wrecker to put the motor in the boat .He was really nervous about my knots but It worked pretty good
meaning nobody got hurt and nothing was damaged.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 11:13pm
Everything went together pretty well considering how long it was apart. All the wires went
on pretty well except for one yellow wire coming out of the harness with a blade connector
that doesn't seem to fit anywhere. The tag was half gone and all I had was the last three letters "ing" .It doesn't reach much past the motor to the front and nothing to the back
It's the wire laying on the port side exhaust.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 11:23pm
Looks good, Gary. Is that the boat you took to Lake George?
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 11:25pm
The tank cleaned up very well.There was a little gunk in the corner under the filler but I was able to get most of it out. I was afraid of corrosion but it looked really good.
Here are a couple of pictures in the water two weekends ago. I gave a friend (the P.O.) a ride and he couldn't stop laughing.He was thrilled to see it back in the water.
It's going to look sweet after it's lettered and striped.I'll get some pictures when it's done.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2015 at 11:51pm
Gary,
It sure has been a long project but some do take time when you have so many other thing going on. I remember when you first started it so it's great to see it in the water. Looking great! What's the other end of the yellow wire attached to? maybe it should be going to the neutral safety switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 10:56am
Hi Bruce. The boat I took to lake george was the reason This mustang didn't get worked on for a couple of years. I sold it so I could devote some time to this one.
Watch your fingers.
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 11:18am
   TRIM
66 Skylark
93 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 11:48am
Trim wasn't used until 1980.
Looking good Gary!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 2:42pm
Pete, the neutral safety switch wires were well labeled and had an eyelet to go onto the two
screws. This wire has a blade connector. I'll check the routing again and see if I can decribe it more clearly.
Tim,the "keep it original" ship sailed awhile ago. I just need it to look neat.
Watch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 3:22pm
I think the ship has already sailed on the trim, Gary... It's hard to install after the fact (I'm assuming the floor carpet is already glued down). Just make a nice tight seam when you do the wall carpet, that's how it would have been done in years prior to the trim anyways. I've never tried doing the floors before the walls though- that may be another difficulty!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 5:22pm
OOPS..
Watch your fingers.
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2015 at 8:33pm
if you only had one oops you have succeeded   i probably had a hundred.
one of my favorite features of my formula and the first time I've ever had it . Snap in carpet
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2015 at 7:57am
I thought about the snap in but it seemed like the glue down was easier . We'll see how it looks after I ge the sides done
Watch your fingers.
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2015 at 9:45am
I just read through this thread from the start. I thought my project took a long time, but you've got me by 6 years or so! Well done, sir!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2015 at 10:52am
Too many irons in the fire will do that to a guy.
Watch your fingers.
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2015 at 12:43pm
Very nice, can't wait to see it painted and striped.
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
