I need a reverse rotation ford 302 dist |
Deadbolt24
Newbie Joined: June-02-2015 Location: Pollocksville, Status: Offline Points: 8 |
Posted: June-02-2015 at 7:19pm |
I'm looking for a Mallory YLM512DV Distributor for my Mercruiser 225 hp Ford 302 ci in my old PennYan boat .
I've been looking for 4 years and I just missed the one on here (this site) back in April 15 for 140.00 and I would have paid more for it but seems I never search when someone has one for sale. haven't figured out the timing thing yetmeaning looking when there is one for sale. so please if any one knows of one or the reverse gear for mine ( has a chipped tooth and don't trust it going back in .I might in a car but not in a boat or a plane) PLEASE LET ME KNOW IF YOU OR YOUR NEIGHBOR HAS ONE LAYING AROUND AND WANTS TO MAKE A COUPLE BUCKS SELLING IT.) Thanks |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6109 |
I could be wrong on this, someone will correct me if so, but I don't think there are reverse rotation distributors. I think they all turn the same way. I think the difference is the gear at the bottom of the shaft which is fairly easily interchangeable, so you need a regular (marine) distributor but a "reverse rotation gear" for it.
Larry, You are correct. |
Deadbolt24
the cam shaft and gear is what is different and the Mallory number is the one I want as it is a electronic and the gears of which I have purchased one from Prestolite either the shaft size is incorrect or the pin size is wrong and it being made of ductile iron which is very easy to screw up so its hard and expensive to modify. so that is why I ask for the whole distributor preferably.
wish I had of been here to get that one that was sold here. YLM512DV and the mallory gear number is 64025 or 9-26823 |
Deadbolt24
How would you like me to word the title to make it clear what I am looking for. I am a mechanic and know all about motors as I have built and modified 100's I just need the whole distributor as I have gone the change the gear route and I want to get a decent non modified electronic distributor is all or a good points one that has a good shaft with good bushings so no wobble that I can convert to electronic. I do hope I've done a better job of explaining what I am looking for. Thank You.
MartyMabe
So none of these will work.? SKIDIM
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3337 |
yup, 82208 seems appropiate
shierh
Years ago i sent both mallory YL's out of my last boat back to mallory to have them overhauled., bushings, springs etc. was very cheep as i remember. THey will likely have what you need.
I htink mr gasket owns mallory now, but they are still responsive liek Steve sez
"ether"?? What did the micrometer tell you?
Any HSS tooling will handle the ductile. Typically all that's needed is to ream for the pin. I have run across taper pins so then you need a taper reamer. |
KeithN
Newbie Joined: June-03-2020 Location: WA Status: Offline Points: 7 |
We have reverse engine rotation distributors for Ford, Chev and Chrysler at closeout prices. aaamarine.com
Keith
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10748 |
After looking at your website, I'm kinda curious.
What happens on 10/2/22? I guess I really don't expect an answer since you haven't answered a question yet in any of your previous posts but there's always a chance. Surprise me
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2068 |
I have a box of distributors at the shop. both chebby and ford. there may be a 302 in that box. dont know if its left or right but you could always change the gear. ill look tomorrow.
KeithN
We have the reverse engine rotation distributor, and it's an HEI (none finer)
Keith
Deadbolt24
Thank you everyone,
I found the distributor I needed and all is well. So on to the next project which is a Datsun 280Z with a first gen 350 lt1 SBC in it. |
Deadbolt24
Thank you everyone for your help. I have found what I was looking for. This is a great site please keep up the great work.
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 276 |
I haven’t been active lately on the site, but wanted to add that I do still have a few composite distributor gears left that will fit the ford 302 reverse rotation, they can also be drilled out to fit the 351 shaft diameter.
BC1982
Newbie Joined: November-28-2022 Location: Tampa Status: Offline Points: 2 |
I'm brand new here and recently purchased an '82 Mustang that I'm working on getting back to running order. I've been looking everywhere for a reverse rotation distributor gear. I'd gladly pay to take one off your hands if you have an extra.
Mille1sj
I still have some available. I sent you a message today. Feel free to call or respond through the message.
Nautiquehunter
I have a reverse 351 distributor I just removed it last week . I will be testing this week if all goes well with sea trials it will be available.
A 351w distributor doesn't fit in a 302 The gear isn't interchangeable either because the shafts are different diameters and the 351 gear would be kinda on the sloppy side. 302 shaft .467 inches 351 shaft .531 inches That's roughly 1/16 inch of slop I suppose the gear could be sleeved down to fit with the right equipment
BC1982
Thanks for the message. I ended up having a local machine shop make one for me (your price is much better). I may still decide to purchase one from you to hold as a spare in case I need it in the future.
Mille1sj
No problem, reach out any time if you need one.
