  New Posts New Posts RSS Feed - Project 67 Mustang
Project 67 Mustang
 Post Reply Post Reply Page    <1 234
ryanibanez88 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ryanibanez88 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 11:55am
did you have to cut it or us the jaws of life
Ryan
1997 Ski Nautique
Midland Texas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 12:10pm
Well I think you know the head answer, might as well get yourself a set of gt40p's. Head work is expensive I have as much in a set of standard heads that a local shop did as I have in my,at the time,brand new P's with larger valves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 12:43pm
Agreed, those heads are anchors now.
Might want to edit the title of this thread now that you've confirmed the boat is a '67!
dochockey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 1:09pm
Where does one go for a set
I've tried to change the title and my profile with no success
1989 Teal Ski Nautique
1967 Mustang
Harris Float
Sunfish
halfnelly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote halfnelly Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 2:22pm
I know the block has 289 stampings, is it a 289? If so, consider having the P heads planed as well since you'll lose quite a bit of compression with the short 2.87" stroke. The old 289 castings were only 54-56cc chambers. GT-40P's are in the neighborhood of 60cc stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 7:14pm
This is where I need lots of help is there a particular brand name I should be looking for ebay, summit should I buy assembled , while I'm at new piston rings etc
1967 Mustang
Harris Float
Sunfish
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 7:36pm
Originally posted by dochockey dochockey wrote:
Ha....Ha      that filter was a bear to get off It has been stuck on there since 199?
'You could have at least painted over the orange so we couldn't see it!!!
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2015 at 7:41pm
Pete, I'm going to post a picture of the ski to I picked up near WL. The Fram filter is still in tact :)
1999 Python
1980 Ski Tique
1968 Mustang WIP
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2017 at 1:17am
So i need some help it turned out the motor was toast
need some recommendations on a replacement ?
1967 Mustang
Harris Float
Sunfish
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2017 at 1:32am
Rebuild the original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dochockey Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2017 at 2:30pm
The block is gone
1967 Mustang
Harris Float
Sunfish
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2017 at 2:50pm
The block is gone
Get a junk yard block.
