Q and A |
Post Reply | Page <12 |
I give, ive spent 2 fricken days on a bad condensor or 2 days on a bad tach feeding back into the coil
electrical is not one of my strong suits |
PLBC
Gold Member Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
missing a piston?
definitely taking some odd guesses here |
Nautique2001
Tachometer causing issues with engine?
boat dr
Ran a compression test on all cyl. #1 thru #7 all 175 lbs. # 8 hardest one to get to,ZERO let me repeat 0000000.what was wrong with this picture????? removed the head,no rod no rings no piston,good reason to be down on power,and that explains the Funny idle...............boat dr
Q C guy had a bad night i guess |
M3Fan
Must be the advance. Missing the vaccuum hose if it is a vac advance, missing the weights if mechanical?
EDIT - Posted too late. I figured since the engine was tested prior to ship it wouldn't be something like a piston. |
Nautique2001
Kurt, you were basically right. Nice job!
boat dr
PLBC, you win the door prize,that one cost me in frustration and time.Send me your cell # and will call you on the next " problem child " that rolls down the drive.......
move to the front of the line Kurt F |
p/allen
Gold Member Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
How was there any oil presure without a rod holding in the oil?
Pat |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5775 |
Wouldn't it be pushing oil out the exhaust valve.
Sounds like a tall tale there Doc, I'm not a believer yet. How the heck does that get test run and pa$$. |
boat dr
P/allen was holding good oil pressure,low press.buzzer was not on at idle either. oil flow to the rod is the last place it goes.
81,that statement to me dont make sense,no piston,no suck,no piston no blow. what would push the oil out the valve.splash would be an issue but there was no oil slick in the water,nor in the y pipe while doing the repower. how did it pa$$ the test run,ask Stillwater,they did not ask for the core all they wanted was the shipping container..........go figure........boat dr |
81nautique
Doc,
It wasn't a statement it was a question, guess the whole thing just sounds a little hard to believe but I'm not calling you a liar. |
p/allen
Once had an asphalt paver that had a 4 cyl continental. It was running bad and couldnt figure it out we were doing tests and had the distributor cap off and it ran on 2 cylinders we also ran it on 2 cylinders with the cap on and the rotor out . Couldnt figure out why . Any suggestions?
Pat |
