‘Project Tique’ photo thread |
Post Reply | Page <12 |
Kristof
Brackets may not be perfect to you, but they d*mn sure look good to me!
Nice work Graham! |
uk1979
I see my list of Graham made parts is getting longer... nice brackets
Lets have a go
gR@HaM
Well it's been a while, I had some time to spare today so managed to make a start on the observer seat foam:
I found these to be very useful for temporarily holding the pieces together Wing nuts to allow the seat to be switched to forward facing if I ever feel that way inclined: Next step to work on the skins, I'm off work till next week so hoping to get a bit more done over the next couple of days.. |
'82 Ski Tique
gR@HaM
'82 Ski Tique
storm34
This is too cool! When are you going to come to Iowa and give us lessons?!
flipflop
Senior Member Joined: June-15-2010 Location: usa Status: Offline Points: 187 |
Looks great. I really like the blue and good job with the upholstery. Adding piping and top stitching really makes a piece look great. Did you have any special attachment to work with the piping?
gR@HaM
Nope just used the machine as it was when i borrowed it and ran as close to the rubber cord as I could, all pretty straight forward
'82 Ski Tique
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
Should find the Starflite seats easy to do after doing these Graham. It is the time of year for these inside projects.
gR@HaM
'82 Ski Tique
Graham - I think you will have an awesome boat when you get it finished!
uk1979
Looks good Graham, are you going to add some kind of lock pin/R clip to stop the platform lifting up and down in the water/waves, as it’s a solid platform and will won’t to lift more than an open slat type... could mark your new gel !!
Lets have a go
gR@HaM
Thanks. Yes, was thinking the same Roger just not worked out the best way of fitting one yet!
'82 Ski Tique
uk1979
Have a look at these, think it's the easy way to go... not all S/S but change the nuts out for S/S so only the body and spring are coated steel,there may well be a all S/S ones somewhere but at the cost £2.24 each I would buy a spare set..just tap one each side of the boat into the slide mounts.
Index Plunger |
Lets have a go
gR@HaM
Wahey thats way better than anything I've come up with!!
Wouldn't be all that bad if I can't find stainless ones could probably get them phosphated in work |
'82 Ski Tique
Roger, You must have some pretty long arms to pull both plungers on both sides at the same time! Look for these: They 1/4 turn lock and are available all stainless. Over here, good old McMaster has them! |
uk1979
Morning Pete, I see your keeping me on my toe’s...we have pull and turn here too just not found all S/S yet...but we do have specialist tools for short arms if this type is used...in this case wood is best. Hope to see you and the Atom at SJRR/Sunnyland. |
Lets have a go
ArtCozier
Hey, that looks just like the special tool that I use to keep engine valves from falling down into the cylinder when air pressure is released as I take the springs off while the heads are on-engine.
"Art"
uk1979
Hi Art, I like it... yes they are a multi tool...can be found hanging on many manual pull out choke knobs. Hope you are well... see you in March for a catch up. |
Lets have a go
uk1979
Lets have a go
gR@HaM
Thanks Roger good find have ordered the Elesa ones
'82 Ski Tique
uk1979
Graham, Glad it was of some help...they look to have a good stock I have bookmarked them, have a look at the rest of their site I see they have lots of different collar rings as well that may work for your new shaft. Roger. |
Lets have a go
gR@HaM
Shall have a butchers, I already have a shaft collar on order but am after some good quality hinges to allow the observer seat to flip down
'82 Ski Tique
leetudor
Groupie Joined: August-29-2014 Location: Mount Juliet,TN Status: Offline Points: 96 |
What is the overall width of the platform plates?
Lee, You may want to be more specific as to which dimension you are looking for. |
leetudor
Of the plates that mount to the boat that allow the platform to side off.
Lee,
Measure the width of your existing bracket, add 1/4" for clearance and then add 1" on each side for the flat heads that hold the assembly together. |
gR@HaM
Yep best measuring your brackets, I used 100mm wide stainless bar 10mm thick
'82 Ski Tique
leetudor
So my bracket is 2.5" wide, would 5" wide bar be too wide?
