  New Posts New Posts RSS Feed - Low temp readings,gauge
 Post Reply Post Reply Page    <1 234
forvicjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forvicjr Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2013 at 11:15am
I have the same issue, gauge reads barely over 100* with fifty degree water temps. Last year mine would get to around 125* with 70* water temps. This info is all from the gauge. I need to hit the t stat with a laser temp gun.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2013 at 11:06am
I guess, after checking all the wiring and screws nuts, and all that!Plus cleaning contacts...
What am I looking for inside the housing?
I know there is a thermo-stat.. But other than that,?
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2013 at 10:32am
   open the T stat housing and check what's inside.
+1
1988 BFN-sold
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 9:08pm
Ty--------Mr.peter will do that...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 9:03pm
Originally posted by eljayrx eljayrx wrote:
Benj - loose screws? The wiring going to the gauge itself? I will check that....
Loose screws and corroded connections mean higher resistance and a low gauge reading. Get the IR gun out and shoot the temp next to the sender. If it reads higher after you have cleaned up the wiring, open the T stat housing and check what's inside.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 7:17pm
No question someone needs to get up in that motorbox and do some probing
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 6:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:41pm
Do you think maybe the gauge is bad? Or wiring has gone funny?
More likely, a few loose screws.
mark c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:27pm
I think we all recognize the internationla symbol for a low temperature condition.
ononewheel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:23pm
By the way,   that sure is a gaudy switch cover.
If we let the professionals do everything it takes all the fun out of youtube
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:22pm
What does the thermo stat housing have to do with LOW temp reading?
What does a shot of your t*ts, or some t*ts have to do with your boat temp?
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:09pm
If it's only getting to 125 you may not have a T stat in there.
My comment was to run it Wide Open Throttle (aka WFO) for a while and see if that doesn't raise the temp.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 5:04pm
Because the Thermostat is inside the housing, if its stuck open, or failed open then you will never get the engine up to temp. If the engine is actually getting up to temperature, and the gauge is just reading wrong, then you may have a wiring issue between the gauge and the sender in the side of the block, or if the sender was removed, and put back in with some kind of teflon tape, or plumbers dope you may no longer have a good ground at the block, which will also make a gauge indicate low.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 4:39pm
Not sure, on any of the responses...
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 4:38pm
juniorwoody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 4:02pm
If you turn the raw water intake a few twists you will find it too hot to touch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 3:55pm
Originally posted by TX Foilhead TX Foilhead wrote:
Maybe you left out a gasket.
Or Blew One
Either way, think it's time for you to inspect all the hoses.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 3:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 3:18pm
Remove the t-stat housing, and we will better be able discuss condition, and that usually generates more heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 3:07pm
try WFO
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 2:55pm
I'll bite. Not a bad photo this time.
Combine that with some oil talk, and photos and you'll get some action.
Guest
Guest
Post Options Post Options   Thanks (1) Thanks(1)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2013 at 1:41pm
I never seem to reach any higher than say 125 on raw water cooled PCM
What is your gauge reading?
