Low temp readings,gauge |
Post Reply | Page <1 234 |
forvicjr
Gold Member Joined: August-24-2012 Location: sc Status: Offline Points: 692 |
I have the same issue, gauge reads barely over 100* with fifty degree water temps. Last year mine would get to around 125* with 70* water temps. This info is all from the gauge. I need to hit the t stat with a laser temp gun.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
Guests
Guest |
I guess, after checking all the wiring and screws nuts, and all that!Plus cleaning contacts...
What am I looking for inside the housing? I know there is a thermo-stat.. But other than that,? |
BuffaloBFN
+1 |
Guests
Guest |
Ty--------Mr.peter will do that...
Loose screws and corroded connections mean higher resistance and a low gauge reading. Get the IR gun out and shoot the temp next to the sender. If it reads higher after you have cleaned up the wiring, open the T stat housing and check what's inside. |
quinner
No question someone needs to get up in that motorbox and do some probing
Guests
Guest |
Benj - loose screws? The wiring going to the gauge itself? I will check that....
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
More likely, a few loose screws. |
mark c
I think we all recognize the internationla symbol for a low temperature condition.
ononewheel
Gold Member Joined: June-21-2011 Location: B Status: Offline Points: 776 |
By the way, that sure is a gaudy switch cover.
If we let the professionals do everything it takes all the fun out of youtube
ononewheel
What does a shot of your t*ts, or some t*ts have to do with your boat temp? |
GlassSeeker
If it's only getting to 125 you may not have a T stat in there.
My comment was to run it Wide Open Throttle (aka WFO) for a while and see if that doesn't raise the temp. |
This is the life
mark c
Because the Thermostat is inside the housing, if its stuck open, or failed open then you will never get the engine up to temp. If the engine is actually getting up to temperature, and the gauge is just reading wrong, then you may have a wiring issue between the gauge and the sender in the side of the block, or if the sender was removed, and put back in with some kind of teflon tape, or plumbers dope you may no longer have a good ground at the block, which will also make a gauge indicate low.
Guests
Guest |
Not sure, on any of the responses...
Do you think maybe the gauge is bad? Or wiring has gone funny? |
Guests
Guest |
What does the thermo stat housing have to do with LOW temp reading?
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
If you turn the raw water intake a few twists you will find it too hot to touch.
quinner
Or Blew One Either way, think it's time for you to inspect all the hoses. |
TX Foilhead
Maybe you left out a gasket.
ononewheel
Remove the t-stat housing, and we will better be able discuss condition, and that usually generates more heat.
GlassSeeker
try WFO
This is the life
ononewheel
I'll bite. Not a bad photo this time.
Combine that with some oil talk, and photos and you'll get some action. |
Guests
Guest |
I never seem to reach any higher than say 125 on raw water cooled PCM
What is your gauge reading? |
