HOORAY!!! I think I have Wet Foam |
Post Reply | Page <12345> |
Holy extra heavyduty secondaries Batman!!!! |
wwchevy
Senior Member Joined: August-22-2011 Location: Michigan Status: Offline Points: 369 |
Pulled the engine out today. Came in to post some pictures and began reading the composite stringer thread. NOW I am more confused than ever. I am planning on using Douglas Fir, but am having second thoughts about putting wood stringers in the boat and just waiting for the rot to begin again. I guess I will take a bunch of measurements, grind out the wood in the transom for the exhaust, rudder and lifting eye and wait for a miracle stringer replacement to come along before Christmas. I wish you guys would hurry up and figure this out for me. I thought this would be an easy job guess I was wrong (sarcasm). I guess I will just take my wife out for dinner and drinks.
No wonder the lag bolts won't tighten up, threads are full of wood pulp. Really considering putting a chevy 350 in this boat. I'm just not a Chrysler guy. |
wwchevy
1989 Barefoot Nautique |
Since you have been going through the stringer threads, hopefully you have picked up on the pro's and con's on doug fir over composite. I really feel it comes down to cost and how much time you want to spend. Composite will cost more and take more time! However, I feel there's nothing wrong with a doug job, CPES and epoxy.
Keep the engine - you're not a Chrysler guy? They make absolutely fantastic marine engines - do NOT compare them to automotive. |
Chryslers sound great, too! Definately old school sound that goes great with that boat.
politicallycorrect
I agree keep it chrysler. That is pretty much as original as you can get. Watch out how you leave it sitting out of the boat. The oil pan is cast aluminum and big bucks to replace.
Scott |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1745 |
Wes. You have to keep the chrysler. Your project looks to be coming along nicely. I dug out foam this week. No fun at all.
BuffaloBFN
+ 1 What do yall think about a composite stringer system as a first project? From what I can tell, composite is more technical along with the time and cost. |
Doing the job exactly like it came only replacing the wood with coosa I dont think it particularily hard in terms of difficulty. (This means refoam and fiberglass skin over the floor. In fact when compared to doing a full cpes job where you take care to seal every screw, hole etc it may in fact be easier to achieve the same result. But there is no doubt the Coosa has some expense. There is the effort to laminate together to coosa into longer shapes for the stringers but after the effort it similar only you dont need to cpes.
It is going foamless that adds some extra steps. |
wwchevy
Hey Guys,
Thanks for all of your input. I am putting the Chrysler engine back in because it is the original engine. The reason I considered changing to a Chevy is that I have an opportunity to buy a marine 350 engine (probably still going to buy it). I think I have made up my mind to use douglas fir, CPES, no foam, drain holes, extra ribs added for strength and leave the exhaust cavities accessible with removalbe panels that span to the secondaries. If I throw some pool noodles in before the floor goes on it will be a last minute decision. I was at that point where I needed to pick a path and move forward and I have. I'm feeling pretty good about the direction I have chosen and believe that based on what I have learned on this site I can do a good job even though I have never worked with fiberglass before. I appreciate all of your opinions and hope to lean on them as I progress and regress all at the same time. Thanks, Wes |
wwchevy
peter1234
the only downside to the pool noodles i used was that mine arent secured and they must move around a bit and the foam is breaking down, also one winter mice got to them . all in all quite a sucess.............
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3238 |
I am not a fan of noodles after I found the heavy as concrete noodles in the bilge of a boat I restored. One must wonder about the quality of the foam used in a cheap toy VS U S Composites closed cell flotation foam. Another thought I have, that I have no research to back it up, but it seems logical to me, is that by increasing the surface area of the foam dramatically as using multiple noodles does, it seems logical that it has much more surface area to absorb water through.
If you use your boat like this I believe some type of flotation is appropriate. Flotation |
what about glueing concrete foam to the underside of the floor, its pink and closed cell, you just dont want a place that will trap water.
will you guys ever go out in a rowboat? |
wwchevy
John,
I hope I never submarine my boat like that, but my wife may drive occasionally (after several weeks of intense instruction) so the boat may see that kind of crazy driving. Eric, I am not going out in a row boat- too much work. Foam of any kind is probably not going into my hull, I just seem to have that thought creep into my mind every now and then. I have a serious question though, when disassembling my engine and trans I found a bunch of rust flakes covering the top of the trans cooler. Obviously not a good situation but I assume the water flows from top down. In your experience does this mean my manifolds are flaking, cutting off water flow to the cooler and contributing to killing my trans? |
wwchevy
wwchevy
When I pulled the engine out of the boat I noticed a core plug (freeze Plug) laying in the bilge along with water and some coolant. I guess that when I drained the block the drain hole was plugged and I didn't get all of the water out. Just filling the engine with coolant was not enough to "winterize" the block. Next time I will keep the drains open when filling with coolant to see it coming out the drain before capping it off. Hopefully no damage like a cracked block, but I am going to disassemble and inspect the engine. Rings, bearings, gaskets, freeze plugs, seals and valve job at a minimum. I am learning alot....the hard way.
Trans crated, need a new damper too. List is getting longer and I haven't even started making a list. |
wwchevy
politicallycorrect
You just trying to slip the picture of the turbo by everyone or what??
wwchevy
Just trying to be funny
wwchevy
fanofccfan
I have two that are not in use if want to get serious.
normally the cooler flow is from the bottem of the boat right to the "in" side of the cooler, how was yours plumbed, I just did a complete r and r of a trans, the guy winterized it when he brought it to me, well i pulled the hose to the cooler and it was packed tight with sea-weed...he told me he seen that and thought it was some type of screen and left it in there...in hindsight he did remember the boat being very sluggish after runs and his temp gauge was not working...so the cooler affects the entire system
wwchevy
I haven't posted in a while, been busy working and going to school- plus sneaking in the stringer replacement job when I can. It has been alot of hard work that has been made easier by the people who have gone before me. I really learned alot from reading on this site and have had no real surprises, except for the cake decorating bag of molten epoxy that I had to throw out of the boat to prevent 3rd degree burns on my hands
I thought I would post a few photos: Pulled out 2 stringers that were good for templates Thank God for Tyvek suits and asbestos rated full face respirators 4 1/2 inch Angle grinder and 15 36 grit flap discs |
wwchevy
wwchevy
I couldn't find clear vertical grain Doug Fir, so I ended up buying construction grade Doug Fir and stacking inside my family room for a month to get it down to 9% moisture content
Wife: how long is that wood going to be in the house? Me: til I put it in the boat. Wife: So, you are saying it is here permenantly? Me: &^%$#@)(*&^ I shaped the stringers using the template stringers, bevel gauge and a carpenters square. Power planer made short work of the changing angle of the bevel. I replaced them one side at a time using 2X for both the main and the secondary stringers. Test fitted them, and then coated with CPES. I made fixtures before removing the stringers, but had to add a small piece of the fiberglass that I removed to compensate for the bare stringers. I replaces port stringers and then removed the starboard and got out the grinder....again!!! Flipped my fixtures around and installed the other stringers, CPES, Cloth, Peanut butter. Filled in some small gaps between the hull and stringers, put in some fillets, and I have 2" and 4" tape down. I am putting 8" and 12" Biax on both sides with 12" biax over the top of the stringers tomorrow. |
wwchevy
wwchevy
How is this for a clueless boat guy who is eternally optimistic:
I am going on vacation the week of the fourth of July and want to take this boat with me (and ski behind it!) My plan is to be done by then. I have been buying parts for the boat all winter- gas tank, fuel pump, fuel hose, rebuilt the carb, exhaust hoses, copper pipe, New damper, rebuilt trans, ladder, the list goes on and on. I wnated to state my idiotic goal in public so that it will motivate me to work night and day to meet my goal. I'm just saying.... |
wwchevy
OverMyHead
Ty Pennington can build an entire house in a week, I'm just saying.
1987 Ski Nautique |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3392 |
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
You are going to be a busy beaver, cool era Mustang.
Wesley,
I'd say you are optimistic for the 4th but just keep going and see what happens. It may work out. So far the job is looking fantastic. |
fanofccfan
Looks great Wes. Have a great 4th of July!
Morfoot
He's looking for us to pump him up, motivitate and help him get er' done. Don't be so negative Pete. he might have the rest of June off. Great job, looking good she's coming along. Ya got exactly 3 weeks left. Drive on with a vengence!
I'm still laughing over this one! |
BuffaloBFN
Looks like super nice work.
storm34
Very nice work. You're getting there..... keep pushing forward!
80SN Barnfind
Senior Member Joined: December-13-2010 Location: Niagara River Status: Offline Points: 122 |
Love the jigs you used to hold the stringers. Looking good, hope you hit your date.
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
