Starter for rr 318 Chrysler? |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1741 |
Posted: December-19-2011 at 7:38pm |
Thanks critter. I gave him those numbers and I have a new one coming.
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
Bill,
These are the numbers off of my spare (not ready to part with) 318 RR starter. MDT-7001 6Y00904 1869297 - (2nd and 3rd digits are very hard to verify, someone hit the starter with a hammer or something) |
1980 Ski Nautique
1966 Barracuda |
fanofccfan
Bruce
Can read the tag that is in the picture? That might give me the numbers I need to order parts. Bill |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Bill,
Looks like your best choice is Marysville. AR 50109 Used on LM318, M340, and M360 CCW/RH Inboard Engines & M383, M400, and M440 CW/LH Engines $245.95 Gary, I know where the starter is located on a marine 318 but really haven't had the opportunity to see where they put them on the automotive version! |
65 'cuda
The 318 starters are in the normal position and are RR.
Bill,
It sounds like you are comfortable with this guy but you also mentioned he may br uncomfortable with the starter since it's marine and a RR. Are you sure it's a RR since many of the marinizations put the starter on the back side of the bell housing which reversed the cranking direction. I suggest another shop or just going back looking for a starter. |
fanofccfan
Pete
It did nothing but click when hooked to a battery. He did say it needed a new armature as this one is shorted out. He has done a whole lot of work for me in the past so I think he knows starters. I don't think he was comfortable With the fact it was marine and also for a rr motor. |
Bill, Does the starter "turn over"? My first reaction is the shop you took it to isn't the greatest due to it missing "tags", they are lost! "all new insides" - was he specific? Did he even get the VOM out and check the armature and field? |
fanofccfan
Pete
I took it to a repair shop...it has no tags or numbers on it for parts ordering. He told me it needed all new insides. I am all ears and do appreciate the help. |
Bill, What's wrong with it? Have you had it to a "auto electric" shop if you can't figure it out yourself? Starters are pretty basic in that if the field and armature is OK then it usually is just a minor "tune up". This involves cleaning up the armature commutator (preferably on a lathe), undercutting the insulation between each commutator contact, installing new brushes and then new shaft bushings. Many will do it themselves. We can help if needed but first, why is it "toast"? |
critter
You might try calling Marysville Marine
Link to Marysville |
1980 Ski Nautique
1966 Barracuda |
fanofccfan
Where is the best place to buy a marine starter for my 318. The one I have is toast.
Thanks Bill |
