Oil filter recommendation for 89 2001 351 |
Author | ||
NautiqueOasis
Newbie Joined: November-05-2017 Location: Dayton, OH Status: Offline Points: 13 |
Posted: November-05-2018 at 12:48am |
What oil filter(s) do you recommend for 89 2001 351 ford
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2870 |
Oil = Valvoline VR1 20W 50
Filter = K&N HP-3001 or WIX 51515XP |
2001SAN
Senior Member Joined: June-26-2012 Location: Ireland Status: Offline Points: 243 |
Agreed on both counts. D. |
A little knowledge is a dangerous thing...
2001 Super Air Nautique 1989 Fairline Corniche 31 www.bannrivercruises.co.uk |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21136 |
Skip the XP with our short change intervals, the regular 51515 is fine. Napa gold 1515 is the same. Motorcraft FL1a is also good. Mobil1 15w50 is another option, the VR1 has gotten pretty spendy.
Well with as many boats that you have... how much is it by you? It’s around 450 here.
I haven’t seen it under $6/qt in several years. Usually about $7.
M1 is $5, give or take. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
Those East coast prices.
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1114 |
M1 15w50
M1-301/M1-301a Easy to find and relatively cheap. |
NautiqueOasis
Thx everyone for your input
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 385 |
Mobile 1 from Walmart......Best filter and Cheapest Price!
Otto
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
Mobile 1 15w50 Motorcraft FL1A filter change every 50 hours. I have been using this since 1989 . Walmart is a good place to buy it.
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6111 |
Going back a ways to gotta be more than one of the 42,000 threads on oil recommendations, I thought we were historically told by folks on here to steer clear of the synthetic oil.. Dont recall reasoning.
In a few of my engine tinkering episodes, the brother of a friend (the friend being the submarine guy I've written about a few times) who was visiting here from MI has worked in the GM engine division forever told me mobil1 was the way to go a few years ago. Did I miss something along the way. |
Yes
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Some say Mobil 1 is even ok for flat tappet engines.
75 Tique
care to elaborate? |
That’s a generic statement that’s probably more incorrect than not. |
You really want to rehash it all? |
Riley
or more correct than not... The authority on the 427 FE Forum swears by it. |
I run Mobil1, but that doesn’t make your statement any less misleading. Most M1 grades have insufficient zddp for FT cams.
Riley
Just saying, some people think it's good oil even for a FT engine, including some CCFs.
Riley
15w50 as recommended above has 1200 parts of zddp.
75 Tique
That's the info I got from a guy that designs, builds and tests engines. I guess the distinction and clarification that I was asking tim for that he didnt give was that the difference was FT vs non FT engines. I wasnt sure what kind the OP's 89 had, that's why I asked the question. |
That statement is correct, but the generic “M1 is ok for FT engines” is not... as you can see, the zddp levels are all over the map and dependent on grade and weight. https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide.pdf All ford marine engines are FT. Chevy went roller around 1997. |
Riley
Jeepers.... |
75 Tique
OK, I think I got it now.
Larry,
Aren't you glad you don't have a ford block in your boat!! |
