’79 Carb in an ’83?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=7992
Printed Date: June-16-2024 at 10:22am
Topic: ’79 Carb in an ’83?
Posted By: freemanca
Subject: ’79 Carb in an ’83?
Date Posted: August-14-2007 at 8:03pm
There is a used Holly carb that came out of a '79 SN on eBay. Would you be able to run this in an '83 SN? Seller doesn't know if it's 600 or 650cfm though.
I have to replace mine and ran across this on eBay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220138949731 - Carb
Thanks,
Chris
Posted By: 79nautique
Date Posted: August-14-2007 at 11:30pm
that's not a marine carb, It wasn't a stock carb for a PCM motor or even anything that would have been in a SN
Date Posted: August-14-2007 at 11:55pm
Wow, really? Well that's the problem i have now, PO put auto carb on.
Thanks,
Chris
Posted By: GottaSki
Date Posted: August-15-2007 at 12:39am
Yes, its nonmarine, and spreadbores don't go on fords. Silly vacuum dashpot on it too.
The seller is smokin something
River Rat to Mole
Posted By: nuttyskier2002
Date Posted: August-15-2007 at 3:10pm
This E-bay seller is either a lier or he doesn't know what he has. His ad states that this is a vacuum secondary. It's very plain to see by the pics that this carb has mechanical secondaries. Also it is a double pumper which means it won't be easy on gas. There's no electric choke and as stated above it is a spreadbore which will require an adapter for your manifold. And yes, it's NOT a marine carb. Stay clear!
------------- 95 Malibu Echelon w/Mercruiser 350 Magnum Skier
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Date Posted: August-15-2007 at 4:12pm
I think he has linked to pics from the web of a carb and is not showing the actual carb off the boat. I asked for actual pics, but no response.
Chris
