2 Senders, 1 Gauge
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=36587
Printed Date: June-17-2024 at 3:00am
Topic: 2 Senders, 1 Gauge
Posted By: 80SN Barnfind
Subject: 2 Senders, 1 Gauge
Date Posted: June-29-2015 at 2:53pm
So I replaced the fuel sending unit in my 80SN a few seasons ago and it worked flawlessly for a year and a half. Mid season last year it began to read only 1/2 when it was actually full...wtf? I go thru the whole wiring gig, checking resisitance, good ground, shunt the gauge...all the checks and all good, have no idea what gremlins are causing this.... we finish the season with trusty 'ol dipstick.
Over this past weekend I figure I'll go thru it all again and pull the sending unit and replace if needed. As you all know the space is tight, visibility is limited and you have to remove a few things to get to the sender, slight pita. I dig in and I'm guiding the sender up and out and it gets to a certian point and stops, so I turn it, change the angle and try again, still caught somehow. .... After further investigation I find the remnants of an old float hanging on the end of the one I'm trying to remove!
Took a while to fish the old one out, but the best part of the story is that it still worked!
------------- Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
