How to run wire for depth finder
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25927
Printed Date: May-08-2024 at 9:28am
Topic: How to run wire for depth finder
Posted By: Union Lake
Subject: How to run wire for depth finder
Date Posted: May-09-2012 at 11:45pm
I have a 96 sport nautique and just got my faria depth finder with a thru hull transducer. I took off the foot kick under the dash and see about a 3 inch hole with alot of wires running down. The faria transducer is wired so I have to run the cable up from the bilge to under the dash. Does anybody have a good way of doing this. Also would the flat area on bottom of hull underneith the transmission be a good spot for the transducer. Thanks
------------- BB
Posted By: baitkiller
Date Posted: May-10-2012 at 12:19am
If you have an old transducer that is unused, you can use that old cable to pull the new one through. If your new 'ducer is through-hull, the opposing side from the engine sea valve seems to a popular spot. If you are doing the in-hull method, fill a zip lock bag with water (no air bubbles) and place it on the hull with the ducer pressed onto it. Move the bag around until you get best signal return at speed and then install it in that location.
------------- Jesus was a bare-footer.............
Posted By: wageslave
Date Posted: May-10-2012 at 3:55pm
I recently had to do this on my 93 sport and I ended up stuffing a fish tape down the hole under the kick space and managed to get it to come out in the bilge in a few tries. It was surprisingly painless; it took maybe five minutes.
Date Posted: May-10-2012 at 5:56pm
Sorry but what is a fish tape. Like a small tape measure? and also where did you end up mounting your transducer? Was it a thru hull style?
------------- BB
Posted By: 00cls1camaross
Date Posted: May-10-2012 at 6:12pm
Fish tape is similar to wire on a spool. It is easy to feed in holes.
http://www.amazon.com/gp/aw/d/B000BP7WBO/ref=mp_s_a_2?qid=1336677101&sr=8-2
------------- 2002 Chevrolet Silverado Z71 33 x 12.50s, BBK, Cranked 2000 Camaro SS Cam, Slicks, Boltons, Stall 1985 Ski Nautique MT1, Board Rack, ACME 542 Future:Stereo, Wrap, Girls
Date Posted: May-10-2012 at 7:34pm
Union Lake wrote:
Sorry but what is a fish tape. Like a small tape measure? and also where did you end up mounting your transducer? Was it a thru hull style? | It's what's used to pull wires through conduit. No hard conduit for you electric required in your area? How about commercial and industrial electrics?
http://www.amazon.com/gp/aw/d/B000BP7WBO/ref=mp_s_a_2?qid=1336677101&sr=8-2" rel="nofollow - Here's a proper link to a fish tape Dakota posted.
Posted By: Bri892001
Date Posted: May-10-2012 at 7:45pm
I did a very similar thing when I added a piggy back ground to my dash: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21901" rel="nofollow - http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21901
Posted By: east tx skier
Date Posted: May-10-2012 at 10:57pm
If there is slack in your throttle cable, you can use it to pull it through. Mine was zip tied all the way down when I tried to snake the perfect pass wires in between the small space between the stringer and the cooler. Real PIA in my case.
------------- http://correctcraftfan.com/diaries/details.asp?ID=2383&sort=&pagenum=7&yrstart=1996&yrend=2000 - 1998 Ski Nautique (Red & Silver Cloud); GT-40; Perfect Pass Stargazer; Acme 422.
Date Posted: May-10-2012 at 11:01pm
Thanks for the pics. I try a snake.
------------- BB
