Transmission Fluid
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25243
Printed Date: April-29-2024 at 3:43am
Topic: Transmission Fluid
Posted By: 73SN
Subject: Transmission Fluid
Date Posted: March-17-2012 at 2:41pm
Just a general question or two: I'm replacing the hoses to the cooler from the transmission. The fluid in the transmission is fairly dark, 39 years and its probably never been changed. Should I change it or just top it off? Does it take plain ole Automatic Transmission Fluid?
Posted By: DrCC
Date Posted: March-17-2012 at 4:29pm
I use type "A" atf. I change fluid every two to three seasons. Should only take slightly over two and a half quarts. Two quart capacity for the Velvet Drive, the rest to fill fluid lines and cooler.
Posted By: 73SN
Date Posted: March-17-2012 at 7:40pm
Thanks, I asked because the local transmission shop advised me not to change my Chrysler fluid/filter. They said problems ensue if you do, only after not changing regularly. I went ahead and drained all fluid today anyway. Is Dexron III OK to use? Wikipedia says its backward compatible. I have Dexron II, Dexron III and something in an old-style can (yes a can) that is Type-F.
Date Posted: March-17-2012 at 10:21pm
Paul, Did you visit a automotive or a marine trans shop? If automotive, that's really a bad choice. The trans's are totally different. NEVER take their advice.
You should have a B/W velvet in the 73.
ATF stated as being "Dexron/Mercon" is the way to go - all you really need to stay away from are the so called "high mileage" fluids. They contain additives you do not want in a marine trans. The same is true for any of the automotive additives - NEVER do it.
Please fill us in and we will be happy to go from their.
Posted By: 73SN
Date Posted: March-17-2012 at 10:54pm
Yep, thought someone may have extra info like the car tranny folks did. Its a Velvet-Drive trans... 1:1. I went ahead with the Dexron III. We gotta-roll, so I had to make a decision and go with it. Hope it wasn't a bad one. We've been down since mid-last-summer with all kinda problems.(atrophy) so cant wait any more. Gotta play soon.
Thanks
