  New Posts New Posts RSS Feed - Draining engine
Draining engine
ben View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote ben Quote  Post ReplyReply Direct Link To This Post Topic: Draining engine
    Posted: October-06-2004 at 8:15pm
Hi, can anyone tell me where the draining plugs are on a 79 ski nautique please. I know of the two on the manifold but where are the others please???
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2004 at 11:31am
Assuming you have a PCM 351 like my '79 SN There are 6 plugs total:
1 at the rear of each exhaust manifold (2)
1 on each side of the cylinder block (2)
1 at the bottom of the transmission cooler
1 at the cast iron elbow at the front of the engine between the thermostat housing and the water circulation pump.
As you know the 2 in the manifolds are quite large, the other 4 are quite a bit smaller. Going on memory it takes a 9/16" socket to remove them.
IrishFooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IrishFooter Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2004 at 4:57pm
I didnt ask the question but I appeciate the answer as well.
1979 Ski Nautique
