PCM rear mount rubber |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
Posted: November-29-2021 at 6:39pm |
The large, lower rubber bushing (w/ metal insert)...........
How in the f(^#@$^*(^$ do you get it into the mount? Thanks
1994 Ski Nautique "Riot"
Hollywood
I left mine in the freezer for a few days before even starting, then I used plenty of silicone grease, a big bolt, nut & washers as a puller. Oh, and a big impact driver.
Pounding them in just caused heat build up and a mushroom effect half way through. Big failure. |
Wilhelm Hertzog
Senior Member Joined: June-14-2014 Location: Cape Town Status: Offline Points: 327 |
I lubed mine up with water soluble lubricant and then pressed it in using a bench vice.
1982 Ski Nautique PCM351W RR II Velvet Drive 10-17-003 1:1 II PerfectPass Stargazer
Do not go gentle into that good night. Rage, rage against the dying of the light. |
MourningWood
"water soluble lubricant"?
Hey Honey?........
Wilhelm Hertzog
Exactly.
MourningWood
and yet, I came up with so, so much more.....
MourningWood
Good news is I got a new bushing. This after trying to press out the inner metal sleeve which I thought might be stuck inside, and thus destroying the bushing. The new one went right in w/ a bit of silicone spray and light shop press pressure. Thanks all...
