Accelerator pump nozzles and cams |
Mille1sj
Senior Member Joined: October-01-2007 Location: United States Status: Offline Points: 276 |
Posted: July-30-2021 at 3:46pm |
After I rebuilt our 302 PCM for the ski Tique I have had an issue where it loses power. If I am cruising at about 8-10 mph and put the throttle down it will momentarily lose power then take off. Quick bog then takes off.
I changed the accelerator pump nozzle from the stock 21 to a 25. It appears to have fixed the issue. I also bought some different cams for the carb but haven’t tried any. Should I just leave it alone now or is there an additional benefit to going to a different accelerator cam? |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2822 |
What color cam is on the carby now?
Mille1sj
Currently it has a red cam.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10605 |
Since it appears to have fixed the issue, why mess with success?
Mille1sj
I was thinking that as well but wasn’t sure if there was any performance or fine tuning reason to mess with the cam.
between cams and nozzles and different volume pump diaphragms, you could probably have enough combinations to drive yourself crazy, I think I'd just leave it alone unless you turned it into a real gas hog.
Besides it's RED and Jonny likes RED
Mille1sj
Since the rebuild it already loves gas.
