  New Posts New Posts RSS Feed - 1990 SN need access to fuel tank
wkeith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkeith Quote  Post ReplyReply Direct Link To This Post Topic: 1990 SN need access to fuel tank
    Posted: October-15-2020 at 10:05am
Looking to replace my fuel sender and need access to fuel tank. Do I have to remove the complete rear bench and frame?
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 10:45am
I'm planning on replacing mine this winter.  On my '92 the rear seat just lifts out.  I expect a '90 is the same.  Just pull it straight up.  Depending on access you may have to disconnect the tank and slide it forward.  Which sender are you planning on using?  I'm going to buy this one:
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkeith Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 10:57am
Thanks, that's the same type of sender I plan to buy. Skiboatpartsonline.com has them also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 1:28pm
We have discussed these in the past. You do some shopping you can find them way cheaper than nautiqueparts. Even the manufacturer list is cheaper. A quick look on ebay turned this up- https://www.ebay.com/itm/323278848377
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkeith Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2020 at 2:41pm
WOW, that's a lot cheaper. THANKS!
It looks to me that I'll have to take out the storage bins under the seat to get to the screws that hold the back cushion in. Anybody know for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkeith Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2020 at 7:09am
On my 1990 SN the hole back seat and storage bins lifts straight up. I did have to slid the tank out a little to get the new sender installed. I bought this one;
Genuine Marine S5 Fuel Water Electric Liquid Level Gauge Sensor Sender Unit, 9.5 Inch, with Gasket (1Pcs) and Screw (5Pcs), Strong Corrosion Resistance, (316 Stainless Steel, 240-33 ohms)
Sold by: Genuine Marine Systems
$37.97
