86 barefoot nautique 454 cooling system |
neilbops
Newbie Joined: July-04-2012 Location: waupun,wi Status: Offline Points: 8 |
Posted: July-11-2012 at 6:29am |
Anyone have a diagram or could explain routing of cooling system of a 84 barefoot nautique 454 gmonster475@gmail.com or 9209607444
Which marinization? PCM?
neilbops
YES
What are you trying to accomplish? Are you re-plumbing the whole system, but lack a reference point? Or are you just trying to understand how your system works?
I believe PCM used the same routing for the 454 as they used on the 351w. Intake grate-->strainer-->tranny cooler-->RWP-->thermostat housing From the thermostat housing, the water can take 2 paths. 1 goes down to the circulation pump, which fills the engine from the bottom up (block-->heads-->intake). It then goes back to the thermostat housing. The other path is out to the exhaust manifolds. Water coming into the stat housing will primarily take this path (directly out the exhaust) when the thermostat is closed. The thermostat controls the flow of water OUT of the engine. |
