  New Posts New Posts RSS Feed - oil pump strainer
oil pump strainer
CraigM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CraigM Quote  Post ReplyReply Direct Link To This Post Topic: oil pump strainer
    Posted: November-22-2025 at 8:08pm
Hey Everyone,
I have a Correct Craft Skier with a Chrysler 318. I am rebuilding the engine. I have purchased a new oil pump but the original tube and strainer is difficult to find. The one I have articulates a little bit and is attached to the end of the tube with a cotter pin. I have cleaned the strainer out and there aren't any obstructions in it. Any suggestions or does anyone know a place I could buy a replacement? Should I use the original? The oil pan is aluminum and is about 7 3/4 deep.
Thanks, Craig
Craig P
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-23-2025 at 9:38am
Here's a link to Harry's Marine, maybe they can help. It'll probably take a phone call
Otherwise, if it worked before and it's clean. I'd have no problem reusing what you have now
Post Options Post Options   Thanks (0) Thanks(0)   Quote CraigM Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2025 at 8:36pm
Thanks for your help and suggestion!
Craig P
Copyright 2026 | Bagley Productions, LLC
