  New Posts New Posts RSS Feed - Red wire w/inline fuse off battery
shortline1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shortline1 Quote  Post ReplyReply Direct Link To This Post Topic: Red wire w/inline fuse off battery
    Posted: June-09-2025 at 6:40pm
2002 ski nautique 196. 330 Excalibur. What's the red 12-gauge wire with an inline fuse, off the pos terminal for?
had a starting issue last fall with my keypad. I found the fuse in that line was burnt/melted. replaced the inline fuse and it fixed the issue. The issue happened again this weekend.  But the wire/fuse is just fine.
Issue: Enter my code, hit start, the light on the keypad goes on as it should, press again (it should start), but it just clicks. And the keypad goes dead until I enter my code again.. repeat......
GOODMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GOODMAN Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2025 at 10:10am
Have you identified the red wire's purpose?  Despite the starter, do other accessories work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2025 at 11:45am
I believe the red wire with in-line fuse is for the keypad.
