  New Posts New Posts RSS Feed - wont pull up a skier when hot
aquaman766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquaman766 Quote  Post ReplyReply Direct Link To This Post Topic: wont pull up a skier when hot
    Posted: May-27-2025 at 8:08pm
My 1993 Nautique hesitates and backfires when pulling up a skier. Once the skier is up it runs fine. It only does this when the engine is hot. So the first skier gets up no problem but the second has trouble. If I back off the throttle quickly and then reapply quickly it will pull the skier up. My thought is carb trouble but it works fine for the first skier. It seems after the temps build under the engine cover it starts to fail. Could it be a bad coil? The boat has always been reliable. It has a 351 ,Holley carb, Mallory distributor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2025 at 11:31pm
When was the carb rebuilt last?  Hesitation or bogging is often a symptom of an accelerator pump circuit that is failing.  Heat can also affect the carb.  The carb and gasoline like to be cooler rather than warmer.  If it was my boat, I'd start with the carb.
As far as the coil -- I've seen a bad coil do strange stuff when it gets too warm, so that is a possibility.  I'm sure that others will join the conversation and provide additional insight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2025 at 2:17pm
Not saying this is your problem, just throwing it out there for consideration.  I spent a month last fall and a couple weeks this spring chasing a "carb" problem.  Even put on a different (not new, just different) carb and boat misbehaved similarly with both carbs. The second carb ran good for an outing or 2 but then started failing just like the first one.  Decided 2 bad carbs was not likely, so I dug a little deeper. Here are my lessons learned.
- a bad coil can have symptoms very similar to carb/fuel problems.  Big dips when accelerating, back firing, stalling, hard starts.  Running fine at lower and higher RPM but really disliking that 2000-3000 rpm range.  Running great at the dock, failing under load.
- a coil having 2 good ohm readings does not necessarily mean the coil is good.  There can be other problems not reflected in the resistance of the coils.
- coil problems can be very intermittent. You might get one whole good ski outing in. You may get one whole good set in, but have it fail for the next guy.  (I did not experience this, but I have read, as Rob mentioned, that a coil, once hot, may fail.  Tho in your case, if it was going to fail with heat, I can't see why it would take 45 minutes to get that hot vs a few minutes for the engine to reach operating temps.  (See comment on "intermittent" failure)
After multiple efforts cleaning the first carb and one effort cleaning the new one, I researched the coil impacts.  Bought a new coil and everything is good.  I was quite relieved to have a $35 fix vs a $700 fix.  (that's cheap enough that its almost worth trying it as a "start throwing parts at it" solution.  Something I abhor and try to avoid.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquaman766 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2025 at 7:18pm
  Thanks guys.  I will start with a coil then get the carb rebuilt if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquaman766 Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2025 at 6:00pm
I just wanted to let you guys know that my problem was a bad ignition coil. I swapped it out and we skied this morning. It ran great, pulled strong and idled smoother. I guess the heat build up under the engine cover made the coil whack out. Thanks for the help. This site has never let me down.
pjsmoreno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjsmoreno Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2025 at 10:05am
Great information guys! Thanks for the info.....
