How wide is a #3 trailer (pre-2001)? |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
Posted: May-26-2024 at 11:25am |
On the older trailers the trailer guides can also be bowed out due to hits over the years. They might stick out more than the fenders.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10735 |
Well you better go boy,,,,,,,,,,and take some pictures too while you're looking at it Here's a picture of a late 70's SN on a standard #3 trailer (The 90 inch wide one) |
NeilMcG
Senior Member Joined: September-20-2021 Location: Pittsburgh, PA Status: Offline Points: 200 |
You're probably right. It didn't look doable when I saw the door. Better to realize this now though. Thanks
That would be a delux, I believe- and built on a lowboy frame. The trailer is likely wider, as the boat fits between the fenders.
NeilMcG
I just read this again and I'm not sure whether it's a standard; I've never seen this trailer before. It's a CC trailer, but has a v-shaped floor between the two bunks and a keel guard, I don't know if that design is wider. Trying head up there asap to measure. |
NeilMcG
Thank you for doing that, and yes Ken tends to be spot on. |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1739 |
Well I did remember to measure and the trailer I have is 90” wide to the outside of the fenders. Somewhere along the line a different axel was installed and it does sit outside the fenders a touch. If the door is 8 feet wide mine would have 2” of clearance on each side. Keno is spot on again!
In case you don't get it measured or if you want an idea what it will probably be for width, here's a comment from TRB buried in an old trailer thread
I'd put a link to the old thread, but it's kinda mind boggling especially without the pictures that disappeared.
fanofccfan
I will try to measure as posted in other thread.
Well, will ya look at that Neil, post it in a new thread with a good title and ..........a 4 minute response time. Looks like we agree on the tightness
Gonna be real tight, probably no way to be certain without measuring. A #3LB likely won’t fit, but a standard #3 should come in just under 8’, so depending on the door trim, it’ll be a game of inches.
NeilMcG
Trying to determine if i can make it through an 8ft wide door.
'78 Nautique |
