Tower - slalom ski |
Post Reply
| Author | |
bwill14
Joined: May-11-2006 Location: United States Status: Offline Points: 75 |
Quote Reply
Topic: Tower - slalom skiPosted: November-03-2006 at 9:13pm |
I tried to do a quick search, so I hope I am not beating a dead horse. We are thinking of adding a tower this offseason. Is it wise to slalom ski on one. The main reason being people in the boat. Hard to have anyone in the back of the boat with the rope going side to side.
Thanks |
Brent
Joined: June-29-2005 Location: NWCT Status: Offline Points: 21276 |
Quote Reply
Posted: November-03-2006 at 9:37pm |
I dont think it would be a problem as long as the tower is attached properly. Quinner pulled at least 3 barefooters on his tower.
bkhallpass
Joined: March-29-2005 Location: United States Status: Offline Points: 4729 |
Quote Reply
Posted: November-03-2006 at 11:01pm |
No manufacturer recommends that you slalom ski from a tower. Most of the pylons and towers have warning labels on them which specifically prohibit use for slalom skiing. If your skier is advanced, he or she will create too much force when pulling out to the side, and it will tip the boat too much. BKH
Livin' the Dream
Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13527 |
Quote Reply
Posted: November-04-2006 at 4:33pm |
If you're just cruising go for it. If you want to go out and lay down the lumber you will pull the boat all over, as well as launch off the wakes.
Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
Quote Reply
Posted: November-04-2006 at 4:43pm |
I put a 7"6 one on my boat in 1997 and all i could remember is tightening the bolts for the pole after a while i didnt think it was a good idea especially when i had 200 lb plus guys wakeboarding behind it. it just seemed like eventually that it would create big dollar problems, well finally my older brother went under the bridge with it, well thats another story that i posted a few months back
bwill14
Quote Reply
Posted: November-04-2006 at 8:05pm |
That could not have been pretty!
I have seen the warning on a skylon pole, but thought if had to do with only having support from the tip of the bow and not much side to side. Thought the tower may be different. Sounds like it comes down to how serious the run is. |
Brent
quinner
Joined: October-12-2005 Location: Unknown Status: Offline Points: 5828 |
Quote Reply
Posted: November-04-2006 at 8:12pm |
I like pulling skiers from the tower when teaching a new skier, gives a little more uplift for getting out of the hole, a novice skier is also fine however like the other guy's said not a good idea or a good pull for serious skiing. I do all my footing, foiling, kneeboarding, wakeboarding and the rare tubing from the tower always.
Post Reply
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
