2004 Instrument gauge issues, it’s not the Gatew |
Nautique Fan
Senior Member Joined: October-24-2010 Location: GA Status: Offline Points: 120 |
Posted: July-30-2022 at 10:14am |
Warning, long post. But, we learned a lot yesterday.
I went to my best friends house yesterday. He has a 2005 SAN 210 and is having gauge issues as well. Since we had both boats there we decided to trouble shoot both our problems and at least leave with one good boat. My boat gauges don’t light up, turn on any back lighting except the ballast tank gauges. They are just dead. We checked and we are getting voltage to the bus wire plug on my boat. So, we figured bad gateway or bad gauges as well. Not so fast…. my buddy has a brand new old stock Gateway that he came across as well. Just a little piece of gold sitting in his garage. We changed out my gateway with the new gateway thinking this was it.. Nope. So, now we decided let’s swap some parts between the boats. We took off my dash and put it on his boat with the new gateway. Boom, all gauges, lights, work except the oil pressure. But, it works on the digital display to scroll through. With his dash on and the new Gateway he still has the same problem he had before where nothing lights up or powers up. We decided to take my old gateway, my dash, my circuit breaker box and put it in his boat. All gauges still light up except the oil pressure gauge which is a faria replacement gauge. So, it may be the gauge is not compatible. Has anyone found a particular wiring issue that fixed their boat? What I do know is that I have a good Gateway, good circuit breaker box and all of my gauges work except the oil pressure gauge. I also know I’m getting good voltage at the bus wire to the gauges. next we took the 3 position switch apart and I alligator clipped the non bilge wires together and I still don’t get power to my gauges. We also changed the two 30A slow fuses under the back seat. We checked the fuse back behind the throttle quadrant as well. I’m stumped but at least I know that my Gateway and most of my gauges are good. Does anyone have any idea where to go from here? Thanks |
1997 Nautique Super Sport
1989 Ski Nautique 2001 (Sold) |
gibson1525
Groupie Joined: November-01-2011 Location: Lake Lanier, GA Status: Offline Points: 69 |
I'm not going to be much help, but I think I've got the same issue as you. I bought a 2004 a few years ago, all gauges worked except the oil pressure. The gateway box was dry. I went ahead and detached the speedo tubing to prevent flooding.
After about a year all the gauges started going out one by one. Now nothing works except the ballast backlighting. I tried all the cleaning fixes I found online with no luck. I had a hard time believing that the gateway box was the issue given that it wasn't flooded.
I haven't spent the time to see what is exactly getting power but I'm very curious if anyone else has had this issue and has a possible solution. |
1988 SN 2001
2004 216 |
Nautique Fan
Hey Gibson1525, do your ballast pumps still work? That is the other weird thing. When I put my circuit breaker box, gateway and dash in my buddies boat his ballast pumps would come on. Mine will not come on in my boat.
Does anyone have a full boat wiring diagram? I looked on planet nautique but only see diagrams for the 40 pin and some dash items (mostly SE version). I think my next step is to get some duetsch connectors and start redoing connections and running jumper wires to see if I can get them to fire up. My buddy with the 05 changed out his capacitors and stepper motors in his gauges and now has all of his gauges working. It may be what you will need to fix yours. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10637 |
I'm kinda curious wondering if you're gonna update your last thread on your 88 SN dash rewiring /bilge pump issues
gibson1525
Yep, the ballast pumps still work.
I'd be interested in hearing more about replacing the capacitors and stepper motors. That's not something I know anything about but I'm willing to try anything to get these things working. I've got two boats and no gauges that work in either right now! Hence the comment from KENO.
1988 SN 2001
2004 216 |
gibson1525
Yea, about that...the wife wanted a tree house built for the kids so the boat got put on hold mid-winter. Then once summer hit I refused to give up any lake time to work on things. So sadly right now it remains in the garage in pieces until ski season slows down. I went ahead and bought all new switches since a few of them were pretty sticky. I'm going to replace them and then start the trouble shooting process to figure out what the heck is going on.
1988 SN 2001
2004 216 |
gibson1525
That's very helpful. I wonder if this is my issue or of there is something else going on as my tach and speedo are also completely out.
1988 SN 2001
2004 216 |
