Oil Pressure Sending Unit- CEL- Help |
Skifunseeker01
Newbie Joined: July-27-2011 Status: Offline Points: 19 |
Posted: July-30-2022 at 7:16am |
My 1999 SN 196 with a GT 40 5.8 has the CEL is on and the boat goes into limp mode right at start up. Last week the CEL was going on after a set or two and the boat would go into limp mode but we would rev the engine up and it would stop. Folks here thought it was the oil sending unit so I I swapped that out, but with the new one the CEL is on at start up. The engine goes right to limp mode. Any thoughts? Bad sensor or is there a relay or something else I can reset or replace. I'll lose the boat to for the rest of the summer if it has to go to the shop. Any suggestions would be great.
Skifunseeker01
I should add in that my oil pressure gauge is acting up too- I give it a tap on the dash and reads correctly, sometimes it bounces but that didn't put the engine in limp mode nor did it trigger the CEL.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10681 |
You must be mixing up your websites, you haven't posted anything here since 2016 and it wasn't about this problem
Limp mode doesn't get a signal from your oil pressure sending unit but there's a tee right at the unit that has an oil pressure switch in it. That sends the signal to the computer for limp mode at 5 psi or less oil pressure or if the switch goes bad and fails in the low direction If you're sure your pressure is good, unplug the switch and your light should go out and you won't be in limp mode any more. There's also a water temperature switch that will put it in limp mode. That could get unplugged too. At 205ish degrees that switch which is independent from the temperature sending unit puts you in limp mode. Those are the only 2 things that put you in limp mode.
Skifunseeker01
Keno, thanks for the info. I'll take a good look at the T and the oil pressure switch. I looked on Nautiques.com website and didn't see a replacement switch available- only the oil pressure sending unit- which I swapped out. Like I said, the oil pressure gauge is acting up but that shouldn't cause the limp mode. I hope it is just a simple fix. I'm off to the boat and will give a follow up. Cheers Dave
If you unplug both the oil pressure and water temperature switches, you won't go into limp mode..........just call it troubleshooting to make sure everything else is good and go skiing hopefully
Skifunseeker01
Keno- thanks for the short term fix and I did get my ski in. Thanks again.
