  New Posts New Posts RSS Feed - Quick drain oil hose
NeilMcG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Topic: Quick drain oil hose
    Posted: June-27-2022 at 9:25pm
Anyone have experience fabricating a DIY oil drain hose? One would think the attachments are basic plumbing fittings, but I'm not sure of bolt/pipe thread relationships so i looked quite comical at home depot ~dazed and confused.
Neil...otherwise known as "Bellagio Boy" (thanks Keno.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2022 at 9:31pm
Well... the 'banjo' fitting that sandwiches between the drain hole in the oil pan and the adapter bolt could be a bit tricky...
I should think that for $45 you can buy a complete kit (from Discount Inboard Marine).
Maybe easier...
1994 Ski Nautique "Riot"
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2022 at 9:57pm
Thanks. That's probably what I'll end up doing. Eliminate the headaches too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2022 at 10:38pm
Neil,
I have one I can part with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2022 at 10:45pm
You're the man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2022 at 6:23am
That could also just be BB for short..............and you're welcome Wink
You might as well get the one from "the man"
Your 78 will have 1/2-20 threads in the oil pan and in the mid 80's Ford changed to M14x1.5  metric threads, so make sure his kit has the right threads or you might still  be dazed and confused
if it was for his 85 SN, you should be in luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2022 at 8:38am
Yea it’s from the ‘85, I’m pretty sure it’s 1/2 x 20 UNF.
I know the GT-40’s are 14 x.1.5,  I’ll check it when I get home and scrounge it out of my parts supply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2022 at 1:45pm
Big shout out to Gun Driver for turning me on to Fumoto's oil petcock drain plug. It's the best solution for oil changes I've ever seen.
Thanks Paul
Fumoto.com
