adding casters to the back of my trailer |
DockDoc
Senior Member Joined: February-17-2014 Location: Charlotte, NC Status: Offline Points: 474 |
Posted: May-21-2022 at 12:24pm |
New garage... driveway slopes down to the entrance, so the prop guard was hitting the garage floor. Super common problem apparently. Actually figured out I could remove the guard and the propeller and rudder had plenty of room, but figured that was a bad idea. Found a mobile welder to come and weld on these brackets, so that I can bolt up these 2000 lbs capacity (each) nylon casters from mcmaster. Hope she holds! |
1993 Sport Nautique
PCM 351w, no ProTec |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2842 |
I used these weld-on wheels/rollers. Worked great.
http://www.pakindustries.com/marine.html JQ
DockDoc
Nice! I debated between Steel rollers and poly wheels. Ultimately decided on the poly (but the ended up with vinyl instead) as I read some reports of steel digging into / damaging the concrete. Figured that was probably overstated. |
1993 Sport Nautique
DockDoc
Here's the final installation... works like a charm! Backed the trailer right up into the garage, the rollers did their thing and it glided right in until the trailer wheels found solid footing again. Very glad I went this way instead of messing around with various ramps etc. |
1993 Sport Nautique
Well done.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10646 |
Maybe your original thread could use a little update
DockDoc
Ah yes will do!
1993 Sport Nautique
63 Skier
Nice solution!
