  New Posts New Posts RSS Feed - PCM rear mount rubber
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: PCM rear mount rubber
    Posted: November-29-2021 at 6:39pm
The large, lower rubber bushing (w/ metal insert)...........
How in the f(^#@$^*(^$ do you get it into the mount?
Thanks
1994 Ski Nautique "Riot"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2021 at 8:46pm
I left mine in the freezer for a few days before even starting, then I used plenty of silicone grease, a big bolt, nut & washers as a puller. Oh, and a big impact driver.
Pounding them in just caused heat build up and a mushroom effect half way through. Big failure.
Wilhelm Hertzog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilhelm Hertzog Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2021 at 5:58pm
I lubed mine up with water soluble lubricant and then pressed it in using a bench vice.
Do not go gentle into that good night. Rage, rage against the dying of the light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2021 at 10:17am
"water soluble lubricant"?
Hey Honey?........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wilhelm Hertzog Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2021 at 11:18am
Exactly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2021 at 4:15pm
and yet, I came up with so, so much more.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2021 at 4:17pm
Good news is I got a new bushing. This after trying to press out the inner metal sleeve which I thought might be stuck inside, and thus destroying the bushing. The new one went right in w/ a bit of silicone spray and light shop press pressure. Thanks all...
