73 Ski Nautique Morse Shift Lever Removal |
Mike1973
Newbie Joined: October-16-2021 Location: Indiana Status: Offline Points: 4 |
Posted: October-16-2021 at 2:15pm |
I have a 1973 Ski Nautique. I'm trying to replace the shift cable. I'm trying to get the unit out of the boat, but I'm stuck. I've taken off the three mounting screws, but now it seems that everything else is screwed on from the back. I don't think I'm supposed to remove that. I'm trying to find a way to get the front cover off to remove the unit. Does anyone have any ideas or know how to do this? Thanks, Mike
Mike
DrCC
You'll need a 7/16" wrench, a mirror, a flashlight.
If you haven't removed the cables. Remove both shift and throttle arms. Then remove the four bolts holding the plate on. |
Mike1973
I haven't removed the cables because I can't get to them. I'm trying to get the whole unit out to replace it. It seems like there should be an easier way to remove it all without cutting in to the fiberglass and without doing it blindly. Any other ideas? Thanks!
Mike
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 931 |
I would remove the seat and lay on your back to look up in there. You don’t need to take the Morse off to change the cables.
DrCC
The mirror and flashlight is used to aid in the "blindly"
Like Sam said, take out the seat, lay on floor, get comfy, have your mirror, flashlight and 7/16" within reach. Maybe put on some soothing tunes. This is the easy way. The sawsall way just makes everything way harder than it needs to be. |
DrCC
Maybe do a google image for Morse shifter to see what you are dealing with.
And remember how the shift and throttle arms are oriented. Because it will be easier for you to remember than it will be for us to explain how to put it back together. |
Mike1973
Thank you for your help with this. I've taken the three mounting screws off the front. It's loose. Can I just remove the plate with the cables on it? Or do I have to disconnect the cables before I can get the thing apart? Is there a way to get the back of the shifter out to disconnect the cables, or do I have to take it all apart upside down?
Mike
DrCC
Yes, you should be able to leave the cables attached to the plate.
Just remove the two control arms ( 7/16" wrench). Then the 4 that hold the plate to the shifter. The plate w/ cables should drop down so you can see it. |
