Help me understand |
sacramentoboater
Newbie Joined: June-06-2021 Location: Sacrament Status: Offline Points: 8 |
Posted: July-17-2021 at 12:50pm |
Drove 2001 SAN with GT40 daily during 4 day houseboat trip, no issues. 25min drive back to marina to pull boat out, was waiting for trailer driver so I started and stopped engine a few times while I bobbed around the marina. I tried to restart my boat one final time and just got a clicking noise from under the dash. No engine turnover, just a click under dash. Brought my boat home and tried a very quick fake a lake start and engine now turns over. Any ideas what may have happened or how to trouble shoot this if it happens again?
gun-driver
Start by having your battery load tested and check your cables and connections for corrosion.
Kirk,
Are you using one of these to clean the battery posts and cable terminals? Also, the battery should be a starting type and not a deep cycle. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
Classic symptoms of battery and cable connectivity issues.
sacramentoboater
Excellent info, will look at all of this. I haven't used the terminal cleaning tools in the pic, but will now!
Thank you
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10637 |
I'd probably be wondering what the clicking noise under the dash was.
A 2001 has a keypad setup for starting the boat, so if you clean whatever connections you're gonna clean and it happens again, I'd be wondering if my keypad/PME box is starting to have issues. You should hope it's just connections You can do a search here or on Planet Nautique for issues with them
gun-driver
Good catch Keno, I didn't catch the under the dash clicking I was thinking under the motor box.
My 2000 Sport just did the same idenical thing to me during a week at the lake but the clicking was at the starter relay. Ended up being a battery with good volts but not under the load of starting. Replaced the 24MS battery (PO installed) with a group 65 and new solder on battery clamps, no more problem. Still would check for low voltage as these GT-40s don't like to start with low voltage.
