2001 Ski 196 Transmission replacement |
lakecountry196
Newbie Joined: June-14-2021 Location: Lake Country BC Status: Offline Points: 3 |
Posted: June-16-2021 at 4:28pm |
I just purchased a 2001 SN 196 GT-40
Beautiful boat It just had a new transmission installed. Initially when I water tested..right after the new install...if you put the boat in FWD gear...the boat would go in reverse...and vice versa ( put in Reverse...boat would go fwd) that was fixed....i now own the boat...issue is. in Neutral...boat rev's fine and throttle is normal...(only using about the first 45-60 degrees of throttle range..revs well passed 4000rpm...) when the boat is in gear...it has a ton of throttle play and will not get passed 32 mph...(3300RPM) ...(full 180 degree throttle from neutral position all the way to the floor...) its slow and lacking ...only goes to 3300 RPM ... i've checked PP and it seems to be fine...anything else possible w the throttle play and lack of power while in gear? |
AM,
Sounds like your cables need adjusting. Give this adjustment procedure a try:
If it works, then the installer should take note as well.
lakecountry196
thanks for the reply, i'll look at that...there's no carb tho on this one...it's FI
MrMcD
Same thing, FI still has a cable attached to the throttle plates I believe. Have any boats gone to electronic throttles? I have not seen one but I have not looked at any newer than 2000 or so.
Yes they have. I think but not 100% sure that's why people who want to go Zero off have to change engines
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10641 |
Like they're saying, your gt40 has a throttle cable Just substitute "throttle body" wherever you see "carburetor" in the adjustment section that Pete posted Check that the cable is firmly mounted to the bracket on the engine too
