Oil pressure level throttling up |
JLawski
Newbie Joined: September-13-2020 Location: Ottawa Status: Offline Points: 4 |
Posted: September-14-2020 at 2:33pm |
Hi All would appreciate your input.My 2003 196 oil pressure goes to close to 500 when throttling up to 36 mph but at idle hovers around 400,any concerns here?Thx
JLawski
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10645 |
I think nobody is answering your post 'cause they're all busy trying to figure out what your units of measure are up there north of the border
Duane in Indy
I am with you Ken. I saw this post this morning and figured 400 BAR would be 5,801.51 PSI, So it aint BAR's Maybe 40.0 psi????
1978 Mustang (modified) |
RealDeez
Senior Member Joined: August-01-2019 Location: MI/IN Status: Offline Points: 125 |
Kpa prolly
Lake James, IN
93 Sport Nautique |
gun-driver
If so 500 kpa = 5 bar = 72.5 psi
A little more info would be helpful
Are you worried about 58 psi at idle or 72 psi at speed? What weight oil are you using? What engine do you have? Have you checked with a mechanical gauge? Did you just get the boat and it has these pressure readings or have you had it a while and the readings just changed?
Salut Tous apprécieraient votre contribution. Ma pression d’huile 2003 196 va à près de 500 lors de la limitation jusqu’à 36 mph, mais au ralenti plane autour de 400, toutes les préoccupations ici? Thx[/QUOTE] Je pense que personne ne répond à votre message parce qu’ils sont tous occupés à essayer de comprendre ce que vos unités de mesure sont là-haut au nord de la frontière
[/QUOTE]
Something tells me that you translated the second post in this thread Pete
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
Just to join the fun...
Привет Всем был бы признателен за ваш вклад. Мой 2003 196 давление масла приближается к 500 при дросселировании до 36 миль в час, но на холостом ходу колеблется около 400, есть ли здесь проблемы? Спасибо
JQ I think one of those agencies with names that have a few letters as an abbreviation will be knocking on your door real soon. Their boss might be somebody named Vladimir or something like that
