80's Martinique Engine Cradle |
searider
Groupie Joined: June-28-2006 Location: South Carolina Status: Offline Points: 92 |
Posted: September-06-2020 at 1:11pm |
For sale. This came from a 1988 Martinique. I planned to use it on a project but ended up now needing it.
Should fit 86-88 Martinique as is and possibly other boats with modification. Measures to fit 21" inside the stringers.
I wouldn’t expect it to fit a Bfn without modifications. Have you measured or checked the fit?
searider
Thanks for the correction, Tim. I changed the listing. I was going by what another member (Hollywood) said in referencing this series Martinique cradle and the BFN having the same width between stringers.
I suspect he was referencing the 2gen MQ which was basically the Bfn hull... but just about any correct craft made prior to ‘88 is going to have the same inside stringer width. That is an industry standard as far as I can tell.
What is likely to be less consistent from model to model is the stringer and floor heights used... we know the 3gen MQ had a taller floor than the Bfn. |
