  New Posts New Posts RSS Feed - Brass drain plug vs rubber
Jay_L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay_L Quote  Post ReplyReply Direct Link To This Post Topic: Brass drain plug vs rubber
    Posted: February-28-2020 at 5:37pm
I have a 1987 Ski Nautique 2001 that I picked up a few months ago.
The last owner was using the traditional rubber drain stop.
I read someplace that since the drain plug is threaded, it is better to use a brass, screw in style drain plug.
Does anyone have an opinion on this ?
Also, the new brass style only turns about 4 full rotations before it won't turn anymore. Is this normal ? I have cleaned the threads and they are clean. It almost seems like the plug is tapered ?
Below is an image. ( excuse the oil around the drain plug. The last owner did a sloppy job of changing the oil )
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 5:44pm
Yea it’s pipe thread, which is tapered. I don’t think using a rubber expansion plug is a good idea at all (which is not for tapered holes). 4 turns is plenty.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 5:47pm
Jeremy,
Evidently the PO lost the plug and went back yard hack with the rubber. Go with the brass threaded. Yes, the threads are tapered since they a 3/4" NPT (pipe threads). The taper is what seals pipe threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay_L Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 6:53pm
That makes sense. Thanks for all the great info !
