Barefoot vs 2001 differences? |
Crmaverick
Senior Member Joined: July-06-2019 Location: Central MA Status: Offline Points: 190 |
Posted: July-17-2019 at 4:13pm |
I've been curious what the differences are between the mid 80's Barefoot and 2001 model. What are the handling/wake differences of the two?
75 Tique
I'll take a stab at it, but there are others a lot more familiar than I.
Speed: 2001 mid to upper 40s BFN upper 40s to low 50s Handling: BFN has v-hull, straked, 2001 is essentially flat bottom from about windshield back. Hence, BFN is better/smoother in rougher water. You won't slide a BFN in a tight power turn, I would guess. Wake, in terms of skiing. 2001 wake is not awful, but its not great. Its hard, not huge. Need a real good edge (which I dont have) to not have your ski bounced in the air. BFN wake is terrible for skiing. Hard, big. you kind of go up one side, across the table, which is kind of high, then drop down off the far wake. That being said, the BFN is a dream to barefoot behind. Smoooooooooth table. My 2 cents, having skied behind both this season. Wake, in terms of wakeboarding. I dont do that, so this is hearsay. 2001 is known for good wakeboarding wake when weighted down. BFN, or in general most v-hulls are not real good for wakeboarding, kind of mushy as I understand it. |
Crmaverick
Was the barefoot alittle faster because of the big block or different hull?
75 Tique
Yes. Both. Tho here is something I never really thought about. The strakes on the BFN hull are referred to as lifting strakes. But its not like they lift the boat up out of the water to the point of less hull in the water. The chines are still in the water at speed. its not like Steve's Bass Nautique that at 75 is just running on the keel. There is still as much wetted surface in the water in terms of width. Difference may be that the bow of the boat is lifted so not so much of the hull lengthwise is in the water. Having thought it through now, for the first time, that is obviously it. The 2001 has all the hydrodynamics of a brick. The BFN is a little more streamlined.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
Not sure I agree with all that. BFN chine is barely in the water at rest, it’s out once the boat is on plane.
Stock vs stock, with consistent engine selection, 2001 and bfn return near identical top end performance (need to compare boats of the same year as speed potential for both hulls changed in 87). |
Kat Daddy
Newbie Joined: June-19-2018 Location: Columbiana, Al Status: Offline Points: 35 |
Reading the post, I get what you are saying, but my BFN is also a 2001? Did each 2001 have its own design? I love my barefoot, the raw power of pulling out of the hole, and the throaty sound at idle. Would you perhaps know what the top RPM is for that big block? My prop is an OJ legend 4 blade 13x16
The only hull feature that the 82-89 SN and 86-89 BFN share is the “2001” decal that Cc put on both. Wildly different hull designs.
That 13x16 will turn even a 454 boat into a slug. 14x14 was original, and 13x13 Or 13x14 modern (Acme) designs will run better. 4400rpm is the stated max RPM but optimal top speed falls off little when letting it spin to 4600 or so. |
rosconole
You can't exaclty reach in a barefoot if its on the trailer because of the V puts it that much higher out of the water. 24" draft vs 30" . owning both I can say the 2001 SN is a the crescent wrench of the ski world. Barefoot is more of 5lb sledge. There is some ever so slight differences I have noticed in the rear deck for what ever reason.
There are certainly similarities in the deck styling and they share a lot of hardware (windshields, most running gear minus the strut, vents, lights etc)... but since the hulls are so wildly different, the decks certainly weren’t coming out of the same mold.
Kat Daddy
At 4k rpm im getting 47-48 mph with the 13x16. I do have an oj 4 blade 13x13, but never tested it to see what it was doing. Wld a 3 blade be better?
rosconole
I have OEM 3 blade didn't really like it compared to 4 blade OJ I have now.
The original 3-blade federal and the 4-blade OJ Legends are both very mediocre props compared to modern cnc Acmes. The most appropriate sizes for the big block DD’s are 3-blades and they work very well.
I suspect your top end speed isn’t gps confirmed? That’s a pretty optimistic top end if the boat was dialed in with the right prop... and that’s not the case with it lugging down at 4000. |
zwoobah
Tim recommended an Acme prop for my Mustang. It transformed my boat. I previously had a Federal, which looked fine but didn't perform well. You won't regret spending money on an Acme.
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 928 |
Some pics to help the discussion. This Barefooter showed up on Badin Lake recently. Good looking boat Greg! I even saw some barefooting behind it on Friday.
75 Tique
Yup, good looking boat. Skis pretty good too, as shown in this video that David captured. Now, if we can just get the fisherman to call it a season.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
Are you just trying to see if anybody tries to look at your "private video" ? I'd look but you have to get rid of that "private thing" |
75 Tique
Stupid new Google/youtube posting procedures, terms, conditions....blah blah blah. Try it now. If still not available, I'll have to dig deeper into a solution. If things aint broke, why mess with them, but it was apparently some new regulations about posting "kid safe" videos, or something like that. In one place it says its private, in another place it says public and there is no way I can check it because, of course, it lets me see it. Argh. |
Whatever you did , it's good now
75 Tique
I set it so kids could see it.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3582 |
It looks a little cold for a Barefoot run but more power to you.
Greg, that BFN looks beautiful!
David, nice job skiing! |
samudj01
Wish I could ski like that. Larry skiing in that take. I was photog.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4229 |
So Larry, now I have to warn my kids not to watch the video? Totally irresponsible to make that public.
Awesome boat, impressive chilly run. We are waiting for our foot of snow to arrive tonight through Tuesday morning, and you are out on the lake. Just not fair! |
rosconole
I suspect lots of fuses are on board on this one!
